Mod Day in SFL.DM2 Coolant Bypass and More
Old Nov 19, 2008 | 12:48 AM
  #46
aRT13's Avatar
wow, it turned out nice.
Old Nov 29, 2008 | 03:55 PM
  #47
_jb's Avatar
_jb
Photographer
Great job on the Coolant Bypass - It really cleans up the front of the motor. I happened to see Danny's G at the Performance factory and it looked really slick.
While I was at the PF, Danny mentioned that DM2 made something to bypass the coolant from going through the plenum next to the throttle body.
Something similar to the copper tubing in the picture above. Seems like it wouldn't be too hard to make... no sense in me buying the tubing and a bender if you guys already make them.
I'm not really sure what the value of the TB bypass of the item in the image is... It looks like it bypasses the coolant flow from the plenum, but still transfers some heat via the copper plate. I'd rather eliminate everything... have to be some benefits to living in Florida.
Old Dec 4, 2008 | 02:00 PM
  #48
rpm06g35's Avatar
Jb we just get rid of that hose all together and leave the hose barbs in the throttle body.
Old Dec 5, 2008 | 12:36 AM
  #49
_jb's Avatar
_jb
Photographer
That makes sense since you're fabricating the whole thing from scratch.
I don't want to drain all the water out of my block, but I'd like to stop hot coolant from going in the plenum by the throttle body. I'm not exactly sure how the tubing runs, but I should be able to use a single piece of rubber tubing to loop between the two pipes if I can get my hands on them.
Old Dec 5, 2008 | 03:57 AM
  #50
SxExCx's Avatar
^I have an easy $3.00 fix for this. Go tou your local autoparts store and ask for a "fuel line union" fitting. I cant remember the size...3/8" maybe?
Just pull the 2 lines that run to the plenum/TB and use the "union fitting" to plug them into each other and use the hose clamps that were on the original hoses..BAM..$3.00 and about 10 minutes and you are good to go.
Next time i install a polished plenum on someones car, I'll do a video DIY.
Well, before I waste my time, does anyone want or even need this?
Old Mar 6, 2009 | 10:19 PM
  #51
tenhigh444's Avatar
Smile coolant bypass
i watched this video were i guy splices a shut off valve into his coolant line going to his throttle body herd its called a coolant bypass
#1 is it that easy
#2 will it hurt my car i don't get how cutting off the coolant to ur throttle body is any good let alone gain u horsepower
please someone explain its driving me nuts
Old Mar 6, 2009 | 10:31 PM
  #52
xx7sephiroth7xx's Avatar
G
The reason that the coolant goes to the throttle body is to keep it from freezing open/closed in very cold weather. If you live in a place like southern California or Florida where the weather never gets to that point, then you can safely cut off the coolant to the throttle body. I assume that since you live in Ontario, in can get pretty cold. In that case, you could shut the valve during the summer and then open it back up again during the winter time. The problem is remembering to open it up during the winter time.
Old Mar 6, 2009 | 10:46 PM
  #53
tenhigh444's Avatar
Smile my G
the video i seen on u tube the guys cut a hose put in a valve 2 hose clamps and they were done
or is there kits out there like im from canada -30c winters +44c summers witch is like 120f so shut it off in the summer then open it in the winter
am i gettin this right cuz im gonna do it
baker2795
Sep 2, 2015 06:00 PM
saskicker32
Aug 11, 2015 02:12 PM
joedaddy1
Jul 28, 2015 02:58 PM
joel extreme
SOCAL Meetings & Events
Jul 23, 2015 04:13 AM
sick_sixspeed
Jul 21, 2015 01:59 PM
