Another Rig Shot
Old Dec 20, 2008 | 04:53 PM
bigc's Avatar
Wings Nation
baaallliiinnnnn!!!
Old Dec 20, 2008 | 05:00 PM
Johnmikins's Avatar
Tight...very tight!
Old Dec 20, 2008 | 05:26 PM
CandlestickPark's Avatar
ill Sedan
Originally Posted by aHeroForEternity
I like this one. The only thing I'd do is adjust the white balance. The ground looks yucky.
Thanks Cal. I adjusted the White balance quite a bit from the image that came out of the camera (entire image was pretty orange/red from the lighting that was present), but I wasn't able to get the ground to change to a normal asphalt color
Old Dec 20, 2008 | 07:00 PM
Calvin's Avatar
Overglorified Altima
Hope you don't mind, but I took a stab at it. My monitor isn't calibrated, so it may not look the same on your end as it does on mine. But it looks just about right on my side.
Original
My Edit:
What do you think? How does it look on your monitor? Your headlights, grille, wheels, and asphalt looked yellow on my end, so I played with those a bit and now they look about right. Then again, my monitor isn't calibrated so that doesn't mean too much. But that's why I'm asking how it looks on your side.
Old Dec 20, 2008 | 07:42 PM
Capthook's Avatar
Great looking Pic! You every coming to ATL?????
Old Dec 20, 2008 | 10:00 PM
ill Sedan
Don't mind at all Cal, looks great, that edit really fixed the photo. The grill, wheels and and asphalt looked off on my end too, I just didn't know what to do to fix it. Thanks again man!
Old Dec 20, 2008 | 10:13 PM
ill Sedan
Cal, just figured out how to make the edit your did in Capture NX (RAW editing program I use) when I was working on another rig shot from this evening. Looks much better, thanks for the heads up man!
Old Dec 20, 2008 | 10:15 PM
SouthBayGSedan's Avatar
Looks awesome Marcus
Old Dec 20, 2008 | 10:17 PM
ttrank's Avatar
Grocery getter
That's all I have to say...
Old Dec 21, 2008 | 12:40 AM
Wannabe6MT's Avatar
-MN G Crew-
I made this pic my desktop background
Old Dec 21, 2008 | 12:52 AM
ill Sedan
Noiiiice! That's pretty cool Janik
Old Dec 21, 2008 | 02:31 AM
Wannabe6MT's Avatar
-MN G Crew-
Lol your probably thinking to yourself. "Pretty sweet, now get that helmet back on" haha
jk
but yea, im excited because im getting a front lip for christmas ! and this pic looks soooo sick.
Old Dec 21, 2008 | 03:10 AM
xx7sephiroth7xx's Avatar
G
Did you try to use the Replace Color tool under Adjustments in Photoshop?
Old Dec 21, 2008 | 08:13 AM
Calvin's Avatar
Kevin - layers are your best friend.
Old Dec 21, 2008 | 08:39 AM
  #30
ill Sedan
Yup I sure did, and couldn't get it to work. What did work was changing the White Balance by setting the Grey Point (a tool I had never messed with before), I usually set the Color Temperature. I'll post my re-edit when I'm done with it.
