30mm spacers on stock 19"s?
Old Jan 19, 2009 | 09:23 PM
g35dan99's Avatar
does anyone know someone running 30mm spacers all around on the OEM 19s? im considering doing it but i want to see how it looks first. TIA
Old Jan 19, 2009 | 09:24 PM
g4dc's Avatar
25mm should work just fine... if you go 30 you need to rool your fenders, if you car is slammed!
It should look ok if you slam your car ....other wise it might stick out to much!
Good luck
Old Jan 19, 2009 | 09:35 PM
g35dan99's Avatar
my car is pretty low so i dont think it'll look bad and i want to go biggg lol i would buy rims but i love the OEMs and why waste a great set of rims? yeah if anyone has any pictures of maybe 25 in the front and 30 in the back it would be much appreciated too!
Old Jan 19, 2009 | 09:42 PM
patman530's Avatar
you should be fine with 30mm's all around. since you're slammed, you will likely need a fender roll on the rear. but it'll be worth it. imo, if you're going to get spacers, might as well go all out and be aggressive. what's the point otherwise?
Old Jan 19, 2009 | 09:44 PM
GreenGoblin's Avatar
The goblin resurrection
Why not measure?
Old Jan 19, 2009 | 09:49 PM
g35dan99's Avatar
Originally Posted by GreenGoblin
Why not measure?
i had the guy at hp motoring measure it when he was putting in my new tires and he said if i wanted to look crazy sick i could go 30 mm all the way around. im guessing it would be close considering the stockers come with +30 F and +33 R.
Old Jan 19, 2009 | 09:52 PM
patman530's Avatar
so that would bring you to +0 F 8.0; +3 R 8.5
I think you should not have much of an issue.
I'm currently running +3 F 9.5 and +4 R 10.5 on mine, and it fits (with some adjustment)
what size tires are you running, stock sizes?
Old Jan 19, 2009 | 09:54 PM
g35dan99's Avatar
yeah thats exactly what i was thinking. im probably going to try it out and if i dont like it, then ill go 25.
Old Jan 19, 2009 | 11:02 PM
jlin615's Avatar
Good luck
+1
30mm is too much for stock wheel
Old Jan 20, 2009 | 01:58 AM
Triple8Sol's Avatar
30 is the way to go. Everyone seems to go with 25 though, since it's a bit more conservative.
Old Jan 20, 2009 | 02:04 AM
bull3t's Avatar
anyone do 30mm all around? I wanna see this too.
Old Jan 20, 2009 | 03:31 AM
Dem1K's Avatar
i agree, go 30 or go home
Old Jan 20, 2009 | 06:07 AM
Dranom's Avatar
DOOOOOOOOOET!!!! 30mm ftw!
Old Jan 20, 2009 | 03:06 PM
g35dan99's Avatar
okay so yeah im going to try it out. what brand should i go with? i know ichiba and h&r.. are there any else? and should i get the ones that come with extended bolts or the ones that you can nut down your original lugnuts and it comes with an extra 5 lugnuts so that you dont have to remove your old ones?
Old Jan 20, 2009 | 03:07 PM
Dem1K's Avatar
built-in studs FTW
