Wrapped Test Pipes
i dont know if i have the v2 pipes, maybe, but i do have the flex pipe, and yes my car has the CEL on 24/7, i have a 2007, and i have no non-foulers because it doesnt work on my year anyway. i think the stock extensions on the test pipe should be perfect with your year.
How so? (I don't mean that in a defensive way.) An explanation would be nice.
nah, i dunno, ill let everybody know if i encounter any problems.
I believe they will crack if the welds are junk. Basically when u wrap a piece of metal with the heat insulation, water will accumulate between the pipe and the wrap. It will eventually eat away at the finish of the stainless and look like **** once you take the wrap off. The only way I see it cracking is due to a lot of heat (aka turbo'd) and water literally being dumped onto the pipes 24-7.
And for whoever was asking about the V2 megan's. I just installed them about a month ago. You will get a CEL. Use the non foulers, they work.
If you have an 04, you have a better chance of not getting a CEL. I Bought Berk Testies because it had the 02 bung built in (no non-fouler needed). It threw a light about a couple hundred miles later..but I just reset the ECU using the pedal method.
kevintandmd
Sep 3, 2015 06:41 PM
