like i said before the more you can ruff it up the better. Even if you take it down to the metal go ahead and us 40 grit on both sides the car and the fiberglass. Its going to look great. Decide on a color yet? Have you seen the new lime green Camaro? That color would look good on your car with the type of wheels i think you might get?
Quote:
Well I just check out the section widths and the Yokohamas run wider than the Generals when tested on an 8.5" wheel (245/35/20) at 9.6" for the Generals and 9.9" for the Yokohamas. On a 9" wheel (255/35/20) it's 10.2" for the Generals and 10.3" for the Yokohamas. Seems pretty good to me.Originally Posted by GreenGoblin
I will ask around, I have no experience with the yokohama's.
Now if only I can get confirmation that the 235/35 won't cause scraping when compared to the 245/35.
My guess is, a 0.25" decrease in diameter shouldn't really lower the car enough to cause any issues since my current scraping issues are from a 1" difference in diameter between the 255/30 (what I have now) and the 255/35 (what should be on the car).
Plus currently my fronts are 18mm bigger in diameter than my rears, which is causing my car to squat in the back.
GreenGoblin
The goblin resurrection
close
- Join DateOct 2006
- LocationIn my garage
iTrader Positive Feedback100
iTrader Feedback Score(66)
Liked:187 Times in 95 Posts
I got part of the cap in today, at least it is enough to start. I started cutting up the car to fit it. Also got welded up a new pipe and made a plate to delete the heater / lines.
The hole looks like it's on the top part of the rear quarterpanel. Are you relocating the gas cap?
Does the gas cap lock in place or anything or can anyone just take it off whenever?
Nice heater delete plate and that hole looks well cut. Good job with the craftsmanship dude.
GreenGoblin
close
- Join DateOct 2006
Thanks guys, yes the gas door is being relocated to the top for the quarter panel. The gas cap is the same one as pictured above....
.JPG)
Plenty more surprises, parts, and trick things still in store.
First interesting build thread on Driver in the last... 4 years. Keep it up, can't wait to see what else u got up ur sleeves.
4drmadness
close
- Join DateSep 2008
- LocationOrange County
iTrader Feedback Score(60)
Liked:59 Times in 48 Posts
keeps on getting sicker everyday! props for doing this!
Really Needs a Life
Dustin@StrafeAutomotive
Really Needs a Life
close
- Join DateJan 2007
- LocationRowland Heights, CA
iTrader Positive Feedback99
iTrader Feedback Score(164)
Liked:177 Times in 136 Posts
so wheres the secret spot for the midget to pop out of when the alarm goes off?
GreenGoblin
close
- Join DateOct 2006
Quote:
Thank Igor, now only if I had some headlight mods... Originally Posted by X-Vert
Quote:
Thanks, now hurry up an finish your car also Originally Posted by lifesgood
Quote:
Well keep checking back I will have more pics soon.Originally Posted by Ryuusei
I'm drooling for more
Quote:
I have an extra setup, that is powdercoated black to delete the coolant line that goes across the front of the timing cover.Originally Posted by Dranom
great craftsmanship! man i need my extra pipe welded like that
Quote:
I actually converted the trunk into his cage instead of doing an audio system, hit the trunk release on the 06 tails and boom he jumps out to attack.Originally Posted by Dustin@StrafeAutomotive
