Reviews Reviews of specific modifications, posted by members
Review: AAM Angled Plenum Spacer-03 6mt.
Old Jul 24, 2007 | 12:27 AM
in2win's Avatar
I recently bought an Altered Atmosphere Plenum spacer from a member on my350z.com. Here is my review and thoughts on the install.
After doing a lot of research I found out it measure 5/8" as compared to a motordyne 1/2 or 5/16". The plenum is angled so this is as the highest point on the spacer (which allows the front to cylinders to breathe more). This plenum spacer is popular on the 350z j because it is angled therefore allowing the stock strut bar to fit.
Install:
Construction and finish looked good and supplied upper Plenum gasket (Nissan) fit well. The only thing that scared me a little was that the two studs on the bottom left and right around the plenum were supposedly not needed to seal the gasket (stock setup uses those studs). In the instructions it said that the gasket would seal properly yet there was not even pressure around the plenum. I ended up using some metric bolts after removing the studs and sealed it properly.
Gains/hp: I noticed a gain throughout the power band rather than at anyone one range. I have an injen intake and a Greddy evo2 installed so I knew it wouldnt be as noticable. However, the car feels faster at mid to redline rpms and acclerates better. I felt more from this mod than from my intake or exhaust together (and I knew this would be the case). Hope this review helps.
Old Jul 24, 2007 | 12:35 AM
kro27's Avatar
Does your hood close with the plenum cover on. or do you leave it off now?
Old Jul 24, 2007 | 01:04 AM
Jtrain's Avatar
LOL, Yeah he has to leave his hood off
Your participles are dangling.
Old Jul 24, 2007 | 02:46 AM
htownboy's Avatar
[QUOTE=Jtrain]LOL, Yeah he has to leave his hood off
Old Jul 24, 2007 | 08:58 PM
in2win's Avatar
I think he meant will the stock engine cover still fit. I havent been running the infinity engine cover because I don't want it to trap heat and I think any real engine doesnt need a cover. I'm not sure if the g35 cover will fit, I;m going to say no because a 1/2" motordyne spacer wont let it so a 5/8" AAM wont either.
Old Jul 24, 2007 | 09:19 PM
GreenGoblin's Avatar
The goblin resurrection
good review
Old Jul 24, 2007 | 10:10 PM
kro27's Avatar
In2win i was thinking the same thing, just thought the angle might make just enough of a difference since its only 5/8 at its highest point. And the rest of you should've known what i meant! Did i miss any punctuation too?
Old Sep 16, 2007 | 09:09 PM
sugsss's Avatar
I have the aam angle plenum spacer and the cover fit's fine just remove the
foam blocks under the cover.
Old Jan 7, 2008 | 08:39 PM
in2win's Avatar
stock engine cover does fit with the plenum spacer. This is a very good mod
Old Feb 24, 2016 | 09:45 PM
dustynhugee's Avatar
Is this spacer good in cold weather! I live in the DC,MD,VA area ?
Old Feb 25, 2016 | 07:01 PM
PhoenixG35's Avatar
lol, that 6 year thread bump. just get the motordyne version with copper addition and you'll be fine in the cold. I'm from Chicago and that's what i have.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
prinny
Nov 22, 2015 11:07 PM
thechitoguy
Oct 1, 2015 05:25 PM
vQFamily
Sep 30, 2015 01:17 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
