Reviews Reviews of specific modifications, posted by members
sxexcx's Custom Grounding Wires // Review //
Old Sep 15, 2015 | 07:14 PM
  #436
SxExCx's Avatar
^ PM sent
Old Sep 21, 2015 | 03:47 PM
  #437
PhroztBite's Avatar
Grounding Kit
2004 Coupe AT Silver shipped to 72753
Old Sep 21, 2015 | 05:38 PM
  #438
SxExCx's Avatar
^ PM sent
Old Oct 13, 2015 | 01:46 PM
  #439
SxExCx's Avatar
bump
Old Oct 16, 2015 | 08:03 PM
  #440
SxExCx's Avatar
bump
Old Oct 18, 2015 | 11:08 PM
  #441
Cody5689's Avatar
2008 G35 5AT Shipped to 37871. What colors does it come in?
Old Oct 18, 2015 | 11:13 PM
  #442
SxExCx's Avatar
^ PM sent
Old Oct 19, 2015 | 04:57 AM
  #443
EPiK's Avatar
2003 6mt coupe, 29588. please
Old Oct 19, 2015 | 12:16 PM
  #444
SxExCx's Avatar
^ PM sent
Old Oct 30, 2015 | 03:40 AM
  #445
EPiK's Avatar
rec'd this kit and very thorough instructions very quickly, and on a great deal. great product, fits perfectly.
one tip, when you remove the bolts to install this kit, use a wire brush or small bit of sandpaper to clean up the grounding points on the motor and the body.
Old Oct 30, 2015 | 03:09 PM
  #446
SxExCx's Avatar
thanks for the feedback
Old Oct 30, 2015 | 03:50 PM
  #447
EPiK's Avatar
No problem man, credit when it's due.
Discovered another possible good side effect today after installing this kit, my fuel gauge goes all the way up now, can't wait see if it stays more accurate now.
Old Oct 30, 2015 | 04:21 PM
  #448
DeafBringer's Avatar
Still trying to understand what exactly this does and the actual benefit other than just looks.
Old Oct 30, 2015 | 04:32 PM
  #449
EPiK's Avatar
The benefit is that electronics have a clear unobstructed path to ground. With all the electric accessories in newer cars, the ground path is often not enough to carry them all. On top of that there is corrosion from not maintaining good contact for years. Basically it allows each accessory to do it's job better. Looks really aren't a factor since if you install the factory engine cover, it is for the most part hidden.
See my post above for just one benefit I've noticed so far in my 6mt 2003 coupe.
Old Nov 6, 2015 | 03:28 PM
  #450
SxExCx's Avatar
bump
