Reviews Reviews of specific modifications, posted by members
Stillen Swaybars
Old Dec 6, 2004 | 03:19 AM
TedRuxpin's Avatar
Im getting mine installed very soon..in 2 weeks... a lot of you guys commented on settings . Im thinking softest front and hardest rear..is that correct?
STillen recod medium for both though.
Old Dec 6, 2004 | 01:29 PM
kenchan's Avatar
Don't over tighten the bracket nuts. I only used a med socket wrench to
loosen from factory torques and tightened it by hand securely. Not sure exactly
what the torque is, but it does not require a breaker bar.
As far as settings go, you should start with soft on both front and back and see
how your car handles. I believe with aftermarket wider tires, you'll probably end up
soft front and med on the rear unless you want to induce more oversteer and go
soft front, hard rear.
With my setup I only needed the rear bar on softest setting for now. Runs
great in wet as well. After you setup your car, make sure you drive in the
wet as well slowly at first just to make sure your tires can handle the added
load.
Old Dec 11, 2004 | 07:21 PM
kenchan's Avatar
I ended up putting on the front bar since I finally got some time for myself.
(wife took my baby son to some stores. yaaay!!! ) The install was
easy.
I drove it around with F: soft / R: med and played with it a little bit.
The stock MichSports seem to be able to keep up with this setting, so will leave
it like that. The sway is much less than before, so I think I like it even more.
Old Dec 11, 2004 | 10:32 PM
Redstradic's Avatar
i just installed mine was well. i didnt even bother dropping the exhaust. i just brought the right side out towards the back of the car and then just wiggled it out. came out very easy that way and just slide the stillen one right back in. car handles great now. i did med/med.
Old Dec 11, 2004 | 10:55 PM
kenchan's Avatar
I think if you have enough room under the car you can do that.
It was just more convenient to loosen that exhaust bracket nut
but not remove it completely.
Old Dec 12, 2004 | 10:53 AM
Hydrazine's Avatar
Red,
What exhaust system are you running?
I have the stillen dual exhaust and there was no moving bars in and out without lowering the exhaust.
Old Dec 12, 2004 | 11:42 AM
Redstradic's Avatar
Originally Posted by Hydrazine
Red,
right now i just have the stock exhaust. it came out prettty easily and i didnt have to force it out. i have read on here that other guys did the same thing, so i tried that first and it worked.
Old Dec 12, 2004 | 12:15 PM
Ehrpower's Avatar
Rear sways only?
Who offers a rear-only swaybar option? Any of the premium companies?
Old Dec 12, 2004 | 12:50 PM
roneski's Avatar
Devil's Advocate
I was wondering about the same thing.
Old Dec 12, 2004 | 02:45 PM
Redstradic's Avatar
here you go: https://www.350evo.com/catalog/produ...5833633ecb07b2
Old Feb 2, 2005 | 04:07 PM
hensta's Avatar
Originally Posted by Redstradic
The web site states it is for a 350z. Does it also fit a G35?
Old Feb 12, 2005 | 11:22 PM
amg35's Avatar
Florida G35 Club
Originally Posted by Q45tech
Run the softest front setting and medium rear setting to avoid the front end washing out more than oem.
It is the Net stiffness shift you want.
If the front bar is equal to the springs then a 10% stiffer front bar is reallly only 5% increase...........the oem rear bar is only 50% [half] as stiff as the springs, so a +50% rear bar nets only 16% rear total stiffness increase ..........+100%= only 33% rear total stiffness increase.
Q45tech,
Based on your settings recommendation, would you suggest leaving the front sway bar oem and replacing the rear bar(for an 05 sedan)? If so, would you recommend the 350evo bar for this duty? Thanks and take care.
Old Feb 13, 2005 | 01:43 AM
Gsedan35's Avatar
Yes, they will fit the G35
Old Feb 13, 2005 | 01:49 AM
Gsedan35's Avatar
Originally Posted by amg35
Q45tech,
Since you have a 05 sedan, you have stiffer oem sway bars thing the 03 and 04 sedans. But, I would still recommend adjustable bars front and rear and for you to tune them to get the car's behavior to where YOU like it. I have my Cusco front bar set at soft +20% and the rear EVO350 bar also set at soft. Next I will up the EVO rear bar to med and test.
Old Feb 13, 2005 | 07:36 AM
  #30
amg35's Avatar
Florida G35 Club
Gsedan35, thanks for the reply. Did the Cusco front sway bar offer something that the EVO front bar did not? And did the EVO rear bar offer something that the Cusco rear bar did not? Just curious as to why you have the mixture of bars. Thanks again.
