Reviews Reviews of specific modifications, posted by members
Voodoo Spun Shift Knob with custom neck
Old Jun 8, 2005 | 09:53 PM
copbait's Avatar
Thumbs up Voodoo Spun Shift **** with custom neck
Parts:
Team Voodoo Spun Aluminum **** $31
Plastic Leg Tips: $1.99
Door Bumper: $1.29
I wanted a shorter shift **** to decrease the throw a little more and also wanted a round **** which are more comfortable in my hand. I went with the Voodoo spun aluminum ****, which were created for the Miatas but have become very popular for other cars as well. It was really cheap at only $31 and the other parts were next to nothing at the local hardware store so overall it was a pretty cheap mod at under $40.
I started out by removing the plastic retainer piece on the original shift boot and trimming the boot down to remove excess material, as the new **** would be lower and require less boot. Sewed the top of the boot back up nice and tight so it was snug against the shaft.
I then cut the rubber bumper in half to remove the larger end because all I wanted was the smaller cylinder end which will serve as a foundation for the leg tip. I had to bore out the center hole of the bumper a bit to get it to slide onto the shaft which it did nicely. They I drilled out the closed end of the leg tip so it would also slide onto the shaft, and fit that down over the rubber bumper I had just installed. Next I just screwed on the shift **** and that was basically it. I did have to cut the leg tip down a bit because it was too tall.
Here is a pic of the parts:
Here is a closeup of the **** installed:
Here is one from a distance:
Another:
The leg tip is the same exact diameter and fits flush with the **** bottom so it feels very smooth and comfortable while shifting. Granted this is just a cheap and ugly hack of a job, but hey I think it looks halfway decent, definitely better than those rubber toilet gasket things I read some people were using, lol.
Old Jun 13, 2005 | 08:11 PM
copbait's Avatar
Even though I liked the shorter shaft length at first, it was a bit too short as my hand was rubbing the boot too much, so I just added a spacer to raise the **** up a bit, and I think I like the look even better...
Old Jun 15, 2005 | 04:58 PM
Byte_Me's Avatar
Nice! I had a Voodoo **** for my Honda S2000 and had the top lazer engraved with the shift pattern and S2000 logo. I loved that thing - probably my favorite mod! Glad to see you can do it on the G as well!
Old Jun 16, 2005 | 04:35 PM
irony's Avatar
do you know the size and pitch of your Voodoo shifter? Is it M10 x 1.25 or M10 x 1.50?
Old Aug 9, 2005 | 02:40 AM
copbait's Avatar
Sorry I don't know, I just ordered the 350z **** from them.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
RWDguy4238
Sep 30, 2015 12:13 AM
blnewt
Sep 25, 2015 01:48 PM
