Does anyone know a good mechanic or shop that does repairs on G?
Old Dec 31, 2009 | 01:46 AM
j_carlo21's Avatar
I have a 2003 G35 manual transmission with around 90k Miles I am having a problem where when I go to turn my car on, I put my foot on the clutch, turn the key and nothing happens. The electronics turn on, but the car makes no attempt to start. I found a member here that had the same problem and he said it was the switch between the ecu and the clutch that completes the circuit to start the car when the clutch is fully engaged.
Does anyone know a mechanic or reputable shop here in san diego that can do it? thanks
Old Dec 31, 2009 | 01:51 AM
JAYY-G35's Avatar
did you try to reset the ECU? but the only guy that touch my car is Grant. check out his thread.
Old Dec 31, 2009 | 02:44 AM
j_carlo21's Avatar
i also had grant installed my plenum spacer for me, upon researching tho, i learned that the problem is the clutch interlock switch, i'll check it in the morning if i can do it or if not i'll probably pm grant, thanks tho myg35izsick, btw your g35 is sick,
chinee
Jun 10, 2024 07:48 PM
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
Ken167
Aug 7, 2015 11:12 AM
newg37
SouthEast
Jul 25, 2015 01:06 PM
