SFL G CLUB South Florida G35's + G37's
Stock 19 Widen
Old Dec 4, 2008 | 06:04 PM
  #31
rpm06g35's Avatar
leeeeeeeeeeroyyyyyyyyyy That was also with the wheel off the ground. Whats the difference when the car is on the ground???? Hook a brother up!!!!!!!!!!!!!!!!!!!!!
Old Dec 4, 2008 | 06:18 PM
  #32
HenryLee's Avatar
Dude if only you could have added those 2inches to the outer rim to make extra 2in lip. Then you wouldnt have to worry so much about the offsets.
Old Dec 4, 2008 | 06:24 PM
  #33
str8dum1's Avatar
good to know. so with a +20 offset, might not even have to add any spacers to add 1.5"
Originally Posted by infinitiGTR2004
Thanks Bruce.
The 1" clearance is with the spacer. See below.
Stock wheel clearance
Attachment 98903
Widened wheel clearance
Attachment 98904
Old Dec 4, 2008 | 10:54 PM
  #34
NyG35fL's Avatar
so, with the stocks widen 2"...what tire size does that make
Old Dec 5, 2008 | 07:57 AM
  #35
escobar929's Avatar
anything from a 275 to 305
Old Dec 5, 2008 | 08:26 AM
  #36
GreenGoblin's Avatar
The goblin resurrection
Originally Posted by ttrank
I need to do this to a set of 18's so I can run some drag radials. It's hard to find an 18x9 with a very high offset for my sedan that's not $400 a wheel.
Do it, the sedan needs more traction...
Old Dec 18, 2008 | 08:51 PM
  #37
str8dum1's Avatar
bump for update...
Old Dec 19, 2008 | 01:10 AM
  #38
ttrank's Avatar
Grocery getter
I found some 18x9.5's that I can use with DR's but I am not 100% sure they will clear my calipers.
Old Dec 19, 2008 | 01:22 AM
  #39
Beebo's Avatar
i believe they can do that
Old Dec 19, 2008 | 07:56 PM
  #40
Chamoru671's Avatar
Stock 19 Widen UPDATE
Got the wheels mounted to the car today. Tires of choice 305/30/19 with ichiba 25mm wheel spacers I can say that by looking at the wheels directly it dosn't look any different unitll you look from behind the wideness is awesome.
Attached Thumbnails Stock 19 Widen-picture316.jpg   Stock 19 Widen-picture-045.jpg   Stock 19 Widen-picture-046.jpg   Stock 19 Widen-picture-050.jpg   Stock 19 Widen-picture044-1.jpg
Old Dec 19, 2008 | 08:11 PM
  #41
O HELLA OEM's Avatar
^looks nicee
Old Dec 19, 2008 | 08:44 PM
  #42
That is why I am sticking with the factory brembos ..... not really I want a 12 pot but to much for me.
Beebo - I do not think they can add to the front of the wheel due to the design. I could be wrong but you would need to call them on that
Earnest- look killer
Old Dec 19, 2008 | 09:01 PM
  #43
Chamoru671's Avatar
^thanks Danny I was going to get the wheels powder coated black, but my boss said no.. so I guess I'll just leave ask it is.
Old Dec 20, 2008 | 12:02 AM
  #44
G35Ian's Avatar
that looks AWESOME!!!!!!!!!!!!!!!!
Old Dec 20, 2008 | 07:59 AM
  #45
Ahahha ya looks good still
