wheel hop anyone????
#96
I had it done Friday before the BBQ at Mike's. It works fine. The factory bushing was gone. It doesn't take much to tear it.... Solid bushing is the way to go. Installation is not difficult but you must have the right tools and know what you're doing. Get a hold of rpm06g35 (MikeRpm) and he will explain..
#102
#103
#105
like rodney said let the bushing sit in dry ice the whole time you ar pulling the exhaust/axles/driveshaft/swaybar and differential out of the car. Also remove the back brace bar(19mm bolts that support the rear subframe w/ 2 14mm bolts in center) later bud give me a shout or keep me posted will send my number via pm later mike
