SFL G CLUB South Florida G35's + G37's
My true Re-Build
Old Aug 9, 2010 | 11:19 AM
ConradoR's Avatar
My true Re-Build
I have been looking into what has to be done to my car to get it up and going again.
This weekend I had it towed to my family’s factory, and worked on taking off the damaged front items.
First was the tire, which got patched and put back on.
After removing everything, it doesn’t seem like the frame got damaged other than the side members.
I have gotten a new radiator support, and started transferring parts that will be attached to it. Today I am buying a new set of right and left stays (they connect the reinforcement bar to the support), and new hood latches.
What was left of the old radiator support:
The radiator seems fine other than the top where the cap screws in got broken. Is it too much pressure to re-attach it?
The fan shroud took a beating. So I am getting a new one. Since a new shroud is $110, I am just getting a Mishimoto Aluminum Fan Shroud for g35 (180 plus shipping).
I have bought a used but perfect condition passenger fender, just has to be painted.
I’m hoping with the side members realigned, and the radiator support (with radiator, shroud, reinforcement/energy absorber, etc) that will take care of the front structure. Then comes the projectors, emblemless grill, new jwt filter, and refinished/repainted nismo front. Let me know if you guys have advice on other brands or used items that you know of...
More as it progresses…
Old Aug 9, 2010 | 01:19 PM
FlopsDaCat's Avatar
WOOW i hope that cow you hit was worth it all
Old Aug 9, 2010 | 05:32 PM
ConradoR's Avatar
Should I get this radiator+fan instead?
Mishimoto Radiator and fans - $350 shipped
Old Aug 10, 2010 | 09:41 AM
ConradoR's Avatar
Pics of removed radiator.
Those side members are cross eyed right now.
Old Aug 10, 2010 | 01:38 PM
TIAN's Avatar
Hold The Line
Yes. Hey man, I lost my phone again so no contacts. I'm not sure if you've called me but text me your number
Old Aug 10, 2010 | 01:43 PM
jwrape's Avatar
Not too bad. I would cut the old stays off and re-weld new ones on. IT would be easier to weld on straight ones than pull those back over. They are really moved over. Not bad damage though. Definately repairable.
Old Aug 10, 2010 | 01:46 PM
Boston's Avatar
Damn. Now I know what you meant with your PM. Looks like you're off to a good start on getting it back together.
Old Aug 10, 2010 | 02:33 PM
ConradoR's Avatar
I believe what you are referring to are the right and left rails.
The bumper stays are the pieces that connect the reinforcement to the radiator support, and I have already ordered those. Those are relatively cheap. (Like $35 bucks each or something like that).
I will speak to the body guy today, and suggest to him cutting the raill section that got bend inward and bending the outer side back to shape, then weld a strong piece of metal that will replace the cut hole. The existing metal is not particularly thick/strong, so by using steel or another compatible quality metal, I don't believe the strength of the member will be decreased.
As a matter of fact, I just notice by looking at the pic that the front sway bar might have gotten bent a little though. I have to check into that.
Old Aug 10, 2010 | 08:07 PM
GreenGoblin's Avatar
The goblin resurrection
The car needs to go on the frame machine bad. The car is a unibody and with the frame rails that tweaked you want to be sure the car will be straight after it's fixed.
Old Aug 11, 2010 | 12:36 PM
elperuano's Avatar
While you got it all apart might as well as go boost!
Old Aug 11, 2010 | 01:32 PM
ConradoR's Avatar
Haha el peruano that's the first thing I thought as soon as I removed the radiator support...
Right now, Im just focusing on making sure the car will perform like it used to/ structurally sound. Then get the body back to perfect.
Theeeeen, in a while, once my wallet forgets about what happened, I will start planning other ways to feed the mod bug ... But I'm not gona lie I sometimes wake up in the middle of the night yelling ptshhh ptshh lol
Old Aug 20, 2010 | 08:57 AM
ConradoR's Avatar
After a lot of research, made a final decision of what shop will be redoing the car.
Car is going in this weekend to Mad Mods, a custom body / fabrication shop in Fort Lauderdale. I made the decision after meeting their guys and seeing the projects in the shops.
I am confident they will do an amazing job,.
There're always ppl asking about goob shops in South Florida, and this way there will be before/after pics to prove it.
I also wanted to say thanks to Danny for helping me along the way.
Little progress I've done.... Installed reinforcement bar, now have to drop the radiator in. New hood brackets that came in are behind it.
Old Sep 15, 2010 | 08:44 AM
ConradoR's Avatar
Got a lot of progress done to the car in the last few days, I'm real happy about it.
I dropped the car off at MAD MODS in Fort Lauderdale, and Danny (AKA GreenGobbling ) went to town on it.
I had the car at another shop but decided to get it towed all the way there on my own expense since I know his skills pertaining to G35s
Anyways, here are some of the progress pics to compare it to the previous pics:
Radiator support/fender work
New radiator installed
Random pictures of the shop
Pictures of some of the new goodies
CS Rear coming soon, TS Hood coming soon
Old Sep 15, 2010 | 11:25 AM
Drako's Avatar
With Danny on the Job you're in excellent hands now...
Old Sep 15, 2010 | 11:32 AM
Project's Avatar
Finally looks like a G again.....hope everything works out for you i cant imagine having the car down that long it will feel like the day you got it.
