SFL G CLUB South Florida G35's + G37's
Lighting help.
Old Mar 31, 2011 | 12:01 AM
FlopsDaCat's Avatar
Lighting help.
Hey guys.
I have a 05 coupe and lately I have been having some lighting problems.
My headlights turn on but for some reason my side markers, license plate, head unit and brake lights don't turn on but my 3rd brake light does work. I checked all my fuses and I don't see any burnt out. I will be heading to Sawgrass Infiniti to see if they can locate the problem but do any of you guys have any clue on what it might be? Also my Dash, directional, and a/c and temp lights do work.
Any and all help would be greatly appreciated.
Old Mar 31, 2011 | 09:46 AM
GreenGoblin's Avatar
The goblin resurrection
Its a fuse, iirc its in the box behind the battery.
Old Mar 31, 2011 | 01:47 PM
FlopsDaCat's Avatar
okay so I checked the fuse and it was blown but for some reason every time I replaced the fuse it kept burning out. What could be causing that?
Do you have a contact number so I might be able to take it to your shop?
side note: I went to sawgrass infiniti and they tried to charge me $150 a hour with a minimum of a two hour deposit, and that is just to tell me the problem not to fix it.
Old Mar 31, 2011 | 02:16 PM
FlopsDaCat's Avatar
second side note:
iv looked around on the forums and found some other people having the same problem and other people saying that led interior lights will cause the fuse to keep burning out. I have changed my lisence plate lights dome lights and door lights with leds. Iv had the leds in for the last month and not had an issue
Old Mar 31, 2011 | 02:18 PM
dphillips2011's Avatar
Try disconnecting the battery and then replacing the fuse.
Old Mar 31, 2011 | 03:56 PM
FlopsDaCat's Avatar
Okay so I found out what the problem was. It turns out that the LED bulb in my license plate melted and the connecters were touching. That is what caused the fuse to kep burning out. Luckly I had a spare LED and I replaced it with a new fuse and now its working.
Hopefully it doesn't happen again.
Thanks for all your help guys.
yosip1115
Forced Induction
Jan 28, 2016 02:51 PM
Silver tiburon
Sep 4, 2015 07:17 PM
eunosz
Aug 29, 2015 02:03 AM
Crappyday
Aug 27, 2015 10:26 PM
JoeMac
Aug 20, 2015 10:17 AM
