FS: Kinetix Front A-Arms
SOLD!!!
up for grabs is a set of used Kinetix front A-arms... approximately 10k miles on them and in superb condition!
150$ + PayPal fees = shipped!
Originally Posted by BadBoy06
why u selling?
Originally Posted by huyberz350gt
i got dibss on thisss... how much is it total wit paypal fee? PM me.. very interested
please elaborate more on the greasing part? does it have to be done ofter or what?
this is directly from kinetix' site:
Detailed Description
Front Upper A-Arms with Camber Adjustability for the 350Z and G35
Complete upper control arm replacement allowing positive and negative camber adjustment of the front wheels. These arms will allow you to either add positive camber to your wheels (EXTEND tire life) or to add negative camber (increase handling). OUR ARMS OFFER THE MOST POSITIVE ADJUSTABILITY OF ANY ARM ON THE MARKET (longer tire life!) The front suspension from the factory allows zero camber adjustability which can become a problem especially when lowering your car. Race enthusiasts also wish to add more negative camber to increase their handling without having to "slam" their car to achieve the desired camber. These arms will allow 1.5 degrees of positive camber, and 1.5 degrees of negative camber from the factory settings. So if your car is lowered 1.5" and the front camber is sitting at 2 degrees negative camber, these arms will allow you to bring them back out to .5 degrees negative camber.
** Will also fit the Infiniti G35 2dr and 4dr
These arms are completey TIG welded and offer a huge upgrade in strength over the factory arms. They use ENERGY SUSPENSION polyurethane bushings for increased responsiveness over the factory rubber bushings. They also use a high quality 3-piece Heim ball joint protected by a polyurethane red dust bootie. These Heim joints offer the best in suspension responsiveness and smooth operation. These Heim joints are also highly serviceable and do not require any special tools to remove. The have teflon coatings inside for "chatter" free operation for years. We have also included grease fittings for even easier serviceability.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
