Reading AT Temps?
Reading AT Temps?
Anyone successful reading AT temps with a Scangauge or equivalent?
I am so used to use the cheap Toyota Techstream options.
Any cheap Consult 3 options? I also have OBD Link but it doesn't find any PIDs for the AT.
There was some HR use with the Hybrids so not sure if these will work. I don't have a Scangauge.
https://www.scangauge.com/support/x-...ssan-infiniti/
Received 2,457 Likes
on
Coupe 6MT Premium RAS
No idea but I believe the factory temp sensor locations are INSIDE the transmission which isn't useful for determining actual tranny fluid temp. You need to install a temperature sensor in the output line from the transmission (before the cooler) so you can read how hot the fluid is that's being pumped directly off the TQ converter. Any readings from the pan or valve body can be 40-100 degrees cooler (depending on load) than actual hot fluid coming off the converter.
LCC0256 (11-17-2019)
I have Nissan Data Scan tool (paid version too) and even it doesn't access these sensors and it seems to know Nissan's systems pretty in-depth. I seem to recall that these data is only available in the TCM, which NDIS doesn't talk to. Some systems, it seems, relay data from their TCMs to the ECU where it is accessible, but Nissan does not.
How does Nissan or their Consult system deal with variations like that ? For example, when checking fluid temperature with Consult (per the FSM), it refers to different temperatures for checking the level at. It wouldn't be reliable if it is "off" by as much as you say.
on
Modern hydraulic oil is incredibly stout even in these kinds of situations, adding a larger external cooler just allows temp to be reduced BELOW engine coolant temperatures in the radiator which in turn lowers the operating temp for the entire transmission. Otherwise the transmission temperature will never drop below engine coolant temperature (measured at the radiator, not the coolant sensor which is on the hot side coolant output at the engine).
OEM equipment is perfectly fine for OEM output but once your engine starts making more torque due to modifications the need for automatic transmission cooling increases beyond what the OEM designed system is built to handle.
LCC0256 (07-08-2019)
on
Looks like the 370Z is the only Nissan ...other than the Infiniti models Scangauge has listed that have AT Temp PIDs available or have been discovered.
I added an AT air cooler to my GX as US models only have the one in radiator. They put in other markets but not US... It has dropped AT temps around 30-35 degrees so far which puts it safely in the low 170s-180s.
Triton3.5 (06-26-2019)
What I'll try and do as a test is use an IR temperature gun on the transmission pan and then drain fluid and measure the fluid to see how much it differs.
treacherous (06-24-2019)
To me, checking it "hot" is the only option. According to the field service manual, to Nissan, "cold" means 86-122º F. Now, I don't know about you, but when I think of "cold" in regards to a vehicle's fluids, I think of the temperature it's at 10 seconds after you start it up, i.e. basically ambient temperature. The manuals says "warm up engine" and check "before driving". Or, it says drive for 5 minutes in an urban area, i.e. city, stop-and-go driving so frequent gear changing, to get the temperature at 149º F. Not a range, right at 149º F.
I've changed mine twice and got 3.25 quarts one time and 3.5 quarts the second time. I seem to recall adding less than 1/2 quart later after the first drain but I believe it was in error because of this cold, hot level confusion (on my part). I'm much more confident with the 3.5 quart amount. Someone on the g35 subreddit said he gets 5 quarts which I find very unusual. 4 quarts, maybe as many others seem to get between 3.5 and 4 anyway. An extra quart ? Maybe he jacks the car up at a 45º angle ! I've done it flat one time and on Rhino ramps another time.
on
on
A big problem with simply replacing the volume that drains out is the HOT OIL has significant expansion compared to the COLD OIL you will be replacing it with. You should always check the AT fluid level after a drain/fill, an easy way to subtract fluid from the pan if you do accidentally overfill is to just use a gear oil pump and a long section of flexible hose. Stick the hose down the dipstick tube and pump out whatever volume you need subtracted, obviously you want to do this with the motor turned off. Much easier than putting the vehicle back on a lift to access the drain pan bolt.
If you have access to a pit then that's the easier option.
Just trying to determine if hot I can get accurate read on the dipstick. Then I would let vehicle cool overnight in the garage with new bottles nearby. At that point fluid temps should be basically the same without the thermal expansion and then can do a drain, measure and refill.
On my Lexus GX 460 I started out thinking it was complicated but really pretty easy. Drain, measure, add 1/2 quart over drained amount, start vehicle up and at 115 degrees release the overfill plug until fluid goes from a stream to a trickle. Close off... you are at accurate fluid level. This overfill plug has a raised piece into the AT pan and is different from the drain. Pretty much the same on all 2004+ Toyota/Lexus trucks.
