P1084
P1084
I’m intermittently getting errors p1084 and p0345.
it seems to be when it’s hot out during the day it will trigger and the crank-start time is extended, the slip, vdc, and ses light illuminate, along with sometimes the abs light.
However it seems later in the day when it’s colder it has no issues and starts right up..
I’ve replaced all 4 cam sensors with oe hitachi
Hello, new member here. I recently got the P1084 code and after some research found a link to the camshaft sensors and the EVT sensor. I changed 2 of the camshaft, 1 on bank one and one on bank 2. I still have service engine light. I notice that the car is running hot while going up hills and the car is idling around 1100 rpm when in neutral or stand still. Im not sure where the other 2 sensors are, how to find them and what my next steps are. Ive been doing alot of research across the forum and since my 06 g35 Manual transmission has 4 sensors i have been looking for them. i did an oil change yesterday and the engine light went away but came back today. Not sure where to start to fix the problem and I was wondering if anyone had any luck.
https://my350z.com/forum/maintenance...084-fixed.html
