2007-2008 G HR strange start up & acceleration issues
2007-2008 G HR strange start up & acceleration issues [SOLVED]
Hello everyone, i own a 2007 G35x with the HR motor and i've been dealing with some strange issues. Firstly on cold start (& letting the car sit for a few hours also) it struggles so bad to start like it's either out of fuel or is looking for its idle then when i give it gas it's goes normal. and if i shut it off and start it right after quickly it starts normally. i've already tested my fuel pump and it's delivering enough fuel, ive checked my plugs which were changed in december 2023 (NGK Laser Iridium) and i've tested all 6 ignition coils and are working in good order.
Secondly under light acceleration at around
1K-1.2K rpm it would dip then continue normally & in 4th and 5th gear trying to accelerate past 2k rpm it would bog and i'd have to firmly press the gas for it to start accelerating. all suggestions are appreciated. as for mods, I have Berk test pipes & custom 2.5 long tube intakes, car is not yet tuned
How many miles? Sounds like a fuel issue - potentially a weak fuel pump. Grab the torque app or any other one that can map AFR and see what you get under heavy acceleration/WOT. It should dip into 11-12s. If it's running in 13-14s - too lean and fuel pump is probably on its way out. You can also cycle the ignition before starting cold to see if that helps. If it does, it would further confirm fueling issue.
See if any of these threads are useful. Mine is the second one that I chased down to a bad fuel pump (posted pics). First thread, the OP narrowed his issue down to cam sensors.
https://g35driver.com/forums/v36-eng...-restarts.html
https://g35driver.com/forums/g35-sed...er-5-5-5k.html
99zx2turd (Yesterday)
AnthonysG
05-28-2021 06:37 PM
tjrob2000
10-03-2019 12:13 PM
