Cold start: low, rough idle then is normal after a few seconds
Old Sep 30, 2019 | 10:21 AM
tjrob2000's Avatar
2007 G35 Journey sedan. A couple of weeks ago I started having a cold start issue (although cold is a relative term in south Texas right now) where it starts, but the idle is only about 500 rpm then after a few seconds or so it will increase to normal rpm of 1800 then settle down to ~700 rpm. I recently did an oil change, spark plugs, and air filters. I did try something recently that has me thinking fuel pressure is not being maintained. I started it up then shut it off after only a couple of seconds then restarted it and it started normally. Possible pressure regulator problem? Car runs fine otherwise. Good power, fuel economy is unchanged at 22mpg.
Tom
Old Oct 1, 2019 | 02:31 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
How does it run at high rpm when it's hot? Any sputter or misfire?
I would suspect the plugs, pull and inspect them, don't just assume because they're new that they aren't the issue. Perhaps a coil pack has a little corrosion on the contact spring up inside the well boot.
Old Oct 1, 2019 | 10:24 PM
tjrob2000's Avatar
It runs fine other than the initial start issue. Plugs don't explain it starting normally if I shut it off quickly and restart.
Old Oct 2, 2019 | 09:26 PM
cleric670's Avatar
BANNED!!!
If you suspect fuel pressure order the sandwich adapter from Z1 Motorsports. I think I got the adapter with a gauge and a fuel test port all for like $65 a couple years ago.
Still worth pulling those plugs though. Especially if you haven't looked at them in the last 50k miles.
Old Oct 3, 2019 | 06:38 AM
tjrob2000's Avatar
I appreciate the input. The plugs are brand new, maybe 1000 miles on them. I have a fuel pressure gauge, just need to make the time to check it. I doubt it's the issue. Perhaps a sticking throttle body? It's behaving better the last couple of days so who knows, perhaps it'll fix itself.
Old Oct 3, 2019 | 12:13 PM
cleric670's Avatar
BANNED!!!
There is no fuel line port on the G35, this is why I suggested the sandwich adapter so you can add one.
j 4 lD
Aug 21, 2013 12:02 AM
Boostd1
Aug 7, 2011 03:53 PM
djbookz
Feb 1, 2011 06:13 PM
theGster
Feb 10, 2010 10:19 PM
Railgunner
Dec 12, 2006 07:07 PM
