G35 & G37, Coupes & Sedans
2006 g35 auto coupe Starts fine then shuts off
Old May 14, 2025 | 04:09 PM
Zmullen's Avatar
G35 coupe 5AT with bose sound system and navigation system
I have had some trouble for a couple weeks now with my ‘06 g35. It started when i was on the highway when it started to jerk while driving but i made it to work ok. A few days later I went to eat and when i left the car would start fine then shut off a couple seconds later. It then periodically began to jerk every once in a while and want to shut off. It sometimes did stall out completely. Also, the same problem where it would start fine, no delay or long crank, then shut back off. Any suggestions on what it may be? This is a video from this morning but it usually stalls out quicker then this! It has thrown a few check engine lights when it happens sometimes but in order to get it started again i have to do ECU reset which usually clears the light so i haven’t gotten a chance to get it read yet. (Video is sped up in order to be able to upload it)
Old May 14, 2025 | 06:27 PM
jbarnett250's Avatar
You really need to get the codes to be more confident you'll get the right part and not waste your time and money guessing the wrong parts. Could be crank sensor. Could be other ignition problem. When you made that video you should have pulled the code before you started it.
Old Yesterday | 05:19 PM
IsaiahGomez's Avatar
Tuo kuulostaa aika selvästi siltä, että ongelma on joko ilmamäärän tai polttoaineen syötössä, ei pelkästään satunnaisesta vikakoodista. Infiniti G35 2006 -mallissa yleisiä syitä tuohon oireeseen on likainen tai viallinen MAF-anturi, heikko kampiakselin tai nokka-akselin anturi, tai jopa polttoainepumpun paineen putoaminen. Se että auto käynnistyy normaalisti mutta sammuu heti, viittaa usein siihen että ECU menettää jonkin kriittisen signaalin käynnin jälkeen. ECU-resetointi vain nollaa oireen hetkellisesti, mutta ei korjaa juurisyytä. Paras seuraava askel olisi lukea vikakoodit OBD-lukijalla heti kun vika on päällä, koska ne katoavat helposti resetoinnin jälkeen.
Jakob with a K
Jan 5, 2024 01:57 AM
Emik8
Sep 17, 2023 11:56 AM
Jakob with a K
Jul 22, 2022 11:09 AM
Nathan_Selby
Oct 18, 2019 02:30 PM
Jgonzalez
Mar 3, 2016 12:20 AM
