Socal's First Official Mod Party!
Old Sep 24, 2008 | 07:06 PM
  #46
SxExCx's Avatar
+1 for Grant
Old Sep 24, 2008 | 07:19 PM
  #47
ShanesG's Avatar
Originally Posted by Strtsk8r321
Ill pay someone to do my springs and camber kit
find someway to get a spring compresser for the front springs and its an easy install!
Old Sep 24, 2008 | 07:22 PM
  #48
RST531's Avatar
Grant do you know how to do the kp fog light module? or anyone that might show up?
Old Sep 24, 2008 | 07:23 PM
  #49
Gdup35sedan's Avatar
ENVautoDetailing.com
Originally Posted by k67p67
You guys should chip in for Grant's gas. Nothing like having a professional on-site.
haha, thanks Kurtis! it's also depending on if i have work saturday-day as well.
-GP-
Old Sep 24, 2008 | 07:24 PM
  #50
i'm no good with electronics, but i can do pretty much anything else on the G (Brakes, Suspension, Engine, Fender Rolling, etc.)
Old Sep 24, 2008 | 07:31 PM
  #51
SxExCx's Avatar
yeah, that foglight module install sucks! I have had mine for 6 months and I am afraid to attempt the install.
Old Sep 24, 2008 | 08:52 PM
  #52
G SEDAN's Avatar
i'll read the instructions and perhaps if you're brave enough we'll attack it together. :-]
Old Sep 24, 2008 | 11:23 PM
  #53
k67p67's Avatar
KP Tech foglight module is not that scary.
Old Sep 25, 2008 | 12:30 AM
  #54
RST531's Avatar
sxexcx - same here i had mine for about 2 months now.
i read the directions but i just dont wanna cut something by mistake. if someone has knows what to do i can do it.
i do most of my mods myself, headlights, taillights, coilovers, front and rear camber kits. i just nervous with wiring.
Old Sep 25, 2008 | 05:30 AM
  #55
FX_Allen's Avatar
yo yo yo... wassup so whos coming? haha ill get my pool ready... of neone wants to chill instead of modding... i think my girl is coming too possibly... so c u
Old Sep 25, 2008 | 06:37 AM
  #56
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
Depending on several factors, I'll try and make it, but I would only be able to stay for half a day at most.
Unless you already have a premade bracket for a projector, I wouldn't try a projector retrofit in a day. I've done it before, but it's not fun working at that pace. It would be easy to do a clear lens swap and color mod. I have a PC power supply that's rigged up to power HID ballasts, and I have a bunch of 300zx clear lenses. (though those lenses are about $100 a pair as a going rate). You could also do LED mods. I buy my LED strips from oznium.com, and it's easy. Just solder on a + and - wire.
Old Sep 25, 2008 | 12:47 PM
  #57
G SEDAN's Avatar
Whats up Albert, glad to see you surface again after the new baby . Hows everything?
Are brackets needed for TSX projectors? How do i go about making one, whats the best material to use? i could try to get that knocked out of the way before the mod day
I need you for the color mod Free lunch if you make it!
Old Sep 25, 2008 | 01:03 PM
  #58
E_K's Avatar
E_K
Baby is up all night. You can see that my first post was at 3 am. Just woke up now.
I figure that you have a G35 sedan. Are you putting the TSX projectors into the low beam section, or fog light section? I know that there's very little room in the stock low beam section. For a bracket, you could either use your stock reflector, or make one out of sheet metal.
Here's how I mounted the TSX projectors on my own car's retrofit using the 03-04 HID reflector from the coupe.
Old Sep 25, 2008 | 01:27 PM
  #59
G SEDAN's Avatar
Sounds like the baby is putting you to work bro
I see what you did, that looks to be a great option. you just dremel out a hole to fit the projectors in and secure it with the bolts on the projectors correct? I do have a sedan and I'd like it to be in teh low beam section but I know S2Ks projectorshave been successfully mounted to TTRANK's lowe beam section, I hope TSX projectors will fit. Were you going to sell me your shroud/bezel you had laying around or should I just find some online? I dont care about teh condition I am going to paint them black anyway.
can you briefly explain the "color mod"? thats that line of bluish color along the cut off right?
Old Sep 25, 2008 | 01:55 PM
  #60
E_K's Avatar
E_K
The shrouds I have are for 3" projectors, and TSX is 2.5". But I can bring them for you guys since I don't have any use for them anymore.
Color mod is simply adjusting the spacing between the lens and the cutoff shield to achieve the best mix of sharpness of the cutoff line with blue/purple color. With the projectors powered up, you can find that exact balance in a few seconds, and then add the appropriate amount of washers to keep that spacing intact.
