South Serving AR, LA, MS, NM, OK, TX
Brake Job
Old Sep 19, 2006 | 02:48 PM
rmeaux's Avatar
Brake Job
I live on the west side of Houston and would like to know if anyone can recommend a good shop to get a brake job at. I have a 2003 G35 6mt with 38000 miles and the Brembo brake setup. An Infiniti dealer has quoted me approximately $675 to turn the rotors and install new pads and I was hoping to get it done for less. I do mostly city driving, so I don't need the most expensive pads around.
Old Sep 19, 2006 | 02:54 PM
filanj's Avatar
if the infiniti dealer told you that they would turn your brembo rotors for you call Brembo and tell them... They will get a sharp pr!ck in their an^s.... do not let them rotate your rotors.. ill find you links for great pads shipped for under $200...
Old Sep 19, 2006 | 03:05 PM
filanj's Avatar
front:
http://cgi.ebay.com/ebaymotors/HAWK-...QQcmdZViewItem
rear:
from an excellent EBay seller. HPS is the way to go. Make sure you use squeal reducer if you DIY which I would recommend bc than the parts is the only cost. If you search the DIY section you will find exactly how to do it. It is very very easy to do.
Old Sep 20, 2006 | 03:51 AM
Cobra-2-G's Avatar
I just went to Sears today and got all 4 rotors resurfaced, EBC pads, and fluid change for $330 out the door.
Old Sep 20, 2006 | 12:03 PM
rmeaux's Avatar
Brake Job
I'm not looking to order pads on line, I'm looking for a reputable shop that will do the job for me. Are you saying Brembo does not recommend turning their rotors before installing new pads, that would really surprise me.
Old Sep 20, 2006 | 01:52 PM
cato's Avatar
SouthernComfort Moderator
I do believe that the Brembo rotors are never supposed to be turned, just replaced.
Old Sep 21, 2006 | 04:08 AM
Cobra-2-G's Avatar
I don't see how. If they have enough material on them all you are doing is smoothing it out again on a lathe. Maybe the slotted ones are different but I have never heard of that.
Too late anyways, I got them done and they work fine.
Old Sep 23, 2006 | 04:11 PM
filanj's Avatar
Surprise! I talked to many shops and Dealers about it and they all highly recommended not doing anything to them. The dealers said they would refuse to touch them unless they were replacing them. Call up Brembo if you have doubts. As for shops.. Depends on the shop, research their suggestions first or you may regret it later
Old Sep 23, 2006 | 04:13 PM
filanj's Avatar
The reason they do not suggest turning cutting/refinishing them is because they become highly prone to cracking etc. I guess it'll be a short-time solution if that is the case
Old Sep 23, 2006 | 09:08 PM
Cobra-2-G's Avatar
From what I know, they go by the outside rim of the rotor as a wear indicator. It if it is at or below this rim, the rotor needs replacing. If it is above, I am not sure how many 1000ths of an inch it is supposed to be above the indicator. If there are no deep grooves and it is just a quick smoothing for the new pads then it should leave plenty above the rim to keep using them.
Old Sep 24, 2006 | 03:33 AM
hayaku's Avatar
Changing brake pads is something really easy to do. You only need a jack, some jack stands and simple hand tools. I reccomend saving the money and doing them yourself. There should a good DIY somewhere on this forum to help you out. Also, are you sure you need your rotors resurfaced?
Old Sep 24, 2006 | 04:12 AM
1stG35inCTRY's Avatar
here in Latvia I got my OEM brembo pads replaced for 28 LVL that is about 50$
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
Hawk196
Sep 10, 2015 10:37 AM
NJ6MT
Sep 10, 2015 08:40 AM
