SouthEast Serving AL, FL, GA, KY, NC, SC, TN
Straight pipe?
Old Jun 14, 2004 | 10:48 AM
BlckMgk's Avatar
Straight pipe?
I know here in florida we don't have immisions test anymore, does this mean I can get a straight pipe installed and remove my Cat. Converter?
If its legal to do, and recomended then, can anyone point me to a mechanic who'll do the procedure, and the estimated cost?
Thanks folks,
-BM
Old Jun 14, 2004 | 01:37 PM
neffster's Avatar
Re: Straight pipe?
It is only legal if you use your vehicle for "off road use only".
301-bhp!!! ...and growing!
Old Jun 18, 2004 | 10:32 AM
BlckMgk's Avatar
Re: Straight pipe?
Darn..
Just to smash the myth though, does it give a gain in HP? or does it mess with the exhaust tuning so bad its very detrimental to do so? I know the O2 Sensors around there, and thats needed for the fuel etc.
Thanks though for the info neffster.
-BM
Old Jun 18, 2004 | 05:33 PM
cryhavok's Avatar
Re: Straight pipe?
Believe it or not, but it is a FL law that NO exhaust system may be modified from stock. Period.
Cats are done under the EPA's Clean Air Act of 1990. Ilegal to modify unless the vehicle is 5 years old or has 50,000 miles.
Straight pipes are completely illegal...with up to a $5,000 fine if you are caught with the cats removed. As you said, however, we don't have emissions tests here in FL, so there is a very slight chance of you being caught. The only thing that could give you away is the bad smell.
Most shops won't install test pipes as a regular service. It is their legal duty to report any cars that come in that are missing catalytic converters. That said, I'm sure you could find a shop mechanic that would be willing to do it "off the records."
Old Jun 23, 2004 | 12:33 AM
COUPEDIT03's Avatar
Re: Straight pipe?
yea but will it actually do anything? Performance wise?
"Dont start none, won't be none"
Old Jun 23, 2004 | 02:10 PM
neffster's Avatar
Re: Straight pipe?
It will do more than a cat back exhaust will, performance wise.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Video Share
Jan 31, 2017 04:00 PM
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
