Need to install my mesh
Old Aug 6, 2007 | 01:12 AM
ExclusiveAutoDetail's Avatar
Hey guys I just got a nismo bumper but the body shop didnt put the mesh on.. Anyway I dont have the patience to take off the bumper and put the mesh in.. It didnt come with anything to support the mesh so I have no clue on what to do.. I am in the Northridge area. If anyone is close by that can do this for me I would greatly appreciate it.
Old Aug 6, 2007 | 02:08 PM
Dan_K's Avatar
Glue gun works fine. But your going to have to take the bumper off.
Old Aug 6, 2007 | 03:20 PM
richiesays's Avatar
you screw the mesh onto the nismo bumper w/ self tapping screws. there should be small indentations on the back of the two inlets.
Old Aug 6, 2007 | 03:25 PM
EricIsKlumzyee's Avatar
+1 thats what I told him.. They're 4cents each at home depot or if you want to swing by again have some for you
- Eric
626-636-6678
Old Aug 6, 2007 | 03:29 PM
JOKER's Avatar
CLUB MODERATOR
+1 on that^ Very easy ****
Old Aug 6, 2007 | 04:03 PM
^ Pix Of Your Car!!! =p
Old Aug 6, 2007 | 04:04 PM
Calvin's Avatar
Overglorified Altima
i would not suggest a glue gun. bumpers get hot sitting in the sun. it won't hold very long.
Old Aug 6, 2007 | 04:09 PM
JOKER's Avatar
CLUB MODERATOR
Waiting................Picking up bumper today @3
Will install immediately and take pix tonight.
Got a quick q on the side markers.
What is the best way to secure them in the bumper. Cuz there is no way you can cut perfect holes out so that they sit there firmly.
I was thinking like a double side tape or something.
Old Aug 6, 2007 | 06:23 PM
side marker just cut a small hole and work your way from there.. it would've been easyer to drill those before painting. but you'll be fine.. double side tape works as well.. you can also pull the clips from the corners out further if you drill too big of a hole..
Installing.. make sure the left and right fenders line up.. once you get that down rest is down hill.. dont forget to close to the hood to check for gaps as well
- Eric
Old Aug 6, 2007 | 06:38 PM
JOKER's Avatar
CLUB MODERATOR
I have done all that . Even cut the holes out and all.
You guys should really perfect your molds and make all that pre maid. That would be supah sweet
Old Aug 6, 2007 | 06:52 PM
Dan_K's Avatar
Unless the bumper gets to 380 deg. F, it will be fine.
Old Aug 6, 2007 | 06:54 PM
Calvin's Avatar
that hot glue gets really weak, even when it's warm.
Old Aug 6, 2007 | 07:12 PM
Dan_K's Avatar
Do I smell a bet? hmm..how hot does a plastic bumper get in the sun? I am guessing no more than 250 degrees.
Old Aug 6, 2007 | 07:49 PM
Calvin's Avatar
hot enough that i wouldn't wanna stick my tongue on it.
i didn't say anything about how hot the bumper gets. i'm just saying that the heat will weaken the glue.
trust me. nothing speaks louder than experience itself (i've been in this exact situation before).
nismo bumper + epoxy + customautomesh = rock flying at the mesh while on the freeway and knocking it out.
didn't wanna take it the bumper off, so i thoroughly cleaned the area...then tried hot glue.
then it baked in the sun and the glue ran a little (no it did not run from after i just glued it, i made sure of that).
then i took it to anh and re re-epoxy'd it for me.
no troubles thereafter.
should have used self tapping screws tho.
Old Aug 6, 2007 | 08:16 PM
savefatkids's Avatar
use screws... i tried using glue on my stock bumper and it fell off after a few months
