i could use some advice
Old Nov 6, 2007 | 10:56 PM
Fiveseven's Avatar
i wasn't getting enough hits on the tech section so hopefully i can get some answers here..
here's a link to my original thread all input would be helpful
https://g35driver.com/forums/showthr...50#post2419550
Old Nov 6, 2007 | 11:03 PM
Fiveseven's Avatar
just checked my brake fluid level.. its a little bit above the min line but not really close to the max.. do i need to add more? if so what kind?
i have attached some pictures if anyone could compare it with theres that would be great :]
Old Nov 7, 2007 | 02:29 AM
gotyamahas's Avatar
only top off fluid AFTER you visually inspect the brake pads....
as the pads wear down the fluid level drops.....
you can use
dot 3 brake fluid....avail @ any auto parts store....
Old Nov 7, 2007 | 07:52 PM
Fiveseven's Avatar
just added more brake fluid problem seems to be gone.. i guess when i got my rear brake job done the tech forgot to add some fluid after bleeding
Fox843
Nov 7, 2015 05:43 PM
Rose M
Oct 12, 2015 10:00 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
