State Referee
Old Nov 20, 2007 | 12:35 PM
oracis2000's Avatar
well.. I know in Cali they are really hard on cars without a cat.. i hope you are prepare for the fine.. cos last time i heard from my friend in Orange County the fine for what they call the straight pipe is close to 1k plus you have to get everything inspected after you put everything back... I have Vortech SC with plenum spacer and used to have the stillen test pipe man do i love that.. cos It almost sounds like a Lambo.. very exotic sound.. but I can't stand taking the risk of get pull over for that fine.. so I put it back the stock cat back.. and yes to answer the question to the smog.. I just did the smog check at a gas station and it passed me with the spacer and SC in it.. and no... i didn't pay extra to the mechanic to pass me! i hope this info help.. and by the way.. where is a meet around OC? i can't seem to find one around? anyone have any ideas?
Kevin
Old Nov 20, 2007 | 12:37 PM
SpeedNStylez_JL's Avatar
Ok I should be good to go I have the skunk 2 5/8" spacer and my CAI is a AEM with the carb legal sticker right there...Thanks for the info bro
Old Nov 20, 2007 | 12:38 PM
Calvin's Avatar
Overglorified Altima
vortech is carb legal. the guy had no idea the plenum spacer is there, i can almost guarantee.
WOW 1K+????? MAN im gonna have to get an extension on that...
Old Nov 20, 2007 | 12:46 PM
Skaterbasist's Avatar
Retired SuperMod
I have heard of $1500... not sure what's accurate or not. Another good reason I need to get my car slammed [enough to obscure a cops view if he decides to check]
Old Nov 20, 2007 | 12:53 PM
Calvin's Avatar
Can't lower it too much. Having it too low is also illegal.
24008. It is unlawful to operate any passenger vehicle, or commercial vehicle under 6,000 pounds, which has been modified from the original design so that any portion of the vehicle, other than the wheels, has less clearance from the surface of a level roadway than the clearance between the roadway and the lowermost portion of any rim of any wheel in contact with the roadway.
Old Nov 20, 2007 | 12:58 PM
Plus my car is slammed and the cop still saw the test pipes...
Old Nov 20, 2007 | 01:00 PM
zackt69's Avatar
rarejdm.com
Plus they have those little mirrors on telescoping antennas to look under the cars... so it really doesn't matter how low you are, they can still check it.
Old Nov 20, 2007 | 01:04 PM
Calvin's Avatar
Henry, I've been pulled over twice with my FI 300 cell HFC's now - not FOR having my HFCs, but I had them on while being pulled over.
One time for speeding, the other time for no front plate, tinted rear place, tinted windows, and exhaust. Neither of the two times did the cop mention me "the smell" or even suspect I had tampered with my stock cats.
Old Nov 20, 2007 | 03:56 PM
SoCalTed's Avatar
What code did you get written for on the two exhaust tickets?
The loud exhaust is non-corrective and you just pay the fine. It is very subjective and the officer just has to say he "thought" it sounder louder than normal. Actually, you are not supposed to exceed 95db, but then again if you argue that you will get smacked with the modified exhaust upon inspection.
The modified / no cat is the expensive one.
Old Nov 20, 2007 | 04:00 PM
Well the first ticket was code: CVC27151 MODIFIED EXHAUST and it says correctable
Second code was: 27156 CATALYTIC CONVERTERS REMOVED and it says correctable
Im not sure what that means. I was planning on going to the smog check and ask them what i should do...Good thing is i get to get both signed off at once. There goes my paycheck
Old Nov 20, 2007 | 05:26 PM
Calvin's Avatar
they're merely fix it tickets then. get them corrected (aka get it fixed), have the ticket signed off, pay the transaction fee, and you should be done. read the back of the ticket. it gives you instructions for "correctable" violations.
Yes, it is.
Old Nov 20, 2007 | 05:55 PM
NICE!! So does that mean i wont get hit with that $1K+ fee from the court?
Old Nov 20, 2007 | 06:22 PM
Calvin's Avatar
Well, I didn't think a cat-delete violation would be a correctable violation. I thought this was a more serious violation.. On your ticket, does it have "infraction" checked off next to the violation description? I figured you'd have to pay a hefty fine AND get it corrected.
If your ticket is a correctable infraction, then you should be able to just follow the directions on the back of the ticket...
Old Nov 21, 2007 | 04:31 AM
  #30
oracis2000's Avatar
well... where do u live in so Cal? I know a guy to ask info about those in Lake Forest.. and if you want.. I can loan you the stock pipe for you to take it to the inspection so you can get it pass the smog..
