Official Info/sign up thread for Socal Double-Din Installation Day(s)
Old Apr 9, 2008 | 03:54 AM
16psibrick's Avatar
Hey Guys,
This thread will serve as the official information/sign up sheet for the “double-din days” I plan to hold down in so-cal. Please read this carefully.
reference this thread if you have no idea what i am talking about:
https://g35driver.com/forums/southern-california/212722-anyone-looking-g-double-din-installations.html
Date: Right now its not completely set yet, but the most likely date(s) is(are) Friday and Saturday, June 27 and 28th. one or two days is dependant on demand. We will have a date set in stone with in the coming week.
Purpose: To help G35 So-cal guys install double din Hus into their vehicles. And no, I don’t actually enjoy doing G35 double dins one after another for two days straight
Cost (labor only unless otherwise noted)
Basic double double-din installation: Includes cost of antenna adapter and wiring harness. Price variation due to nav/non nav and other features that require additional labor (i.e. Avic Z2’s mic)
2003-2004: $150-175
2005+: $125-$150
Accessories installation:
IPod adapters: $25-$50 (Avic-D3 cable coming out of the upper cubby is free)
Bluetooth Adapters: $25-$50 (Avic-Z2 BT adapter is free)
Satellite Radio/traffic modules: $50
Steering wheel controls retention: $100 (this includes the cost of the
module, which needs to be purchased through me so I can pre-wire and program the module before hand)
pac TR7 for alpines $50 (for module and labor)
Stock navi voice retention: $100 (for those installing DVD double dins and want to keep the nav voice operating)
Backup Camera: $100-$125 (labor only) depending on sedan or coupe, we will NOT be doing drill-type bullet cameras, only good surface mounted units, similar to the pioneer backup cameras. We simply don’t have the time to do any custom mounting configurations with drill-type of cameras.
Added: Ipod adapter install on stock headunits, assuming you will be using a standard plug and play kit.
if cable comes out of stock upper cubby (non nav) $50
if cable comes out of upper glovebox (non nav) or center armrest area: $75
Before signing up:
What you will need to bring:
1. Your car
2. Double-Din Finisher and ac controller (www.grubbsperformance.com is one of the sources to get them), you do NOT need the bracket. We will NOT be doing dual buttons, so if you must have the dual button, I suggest you pick up the version pre-loaded with the dual button in place.
3. Any accessories you plan to add, except steering wheel controls adapter, that I require you to purchase through me so I can pre-wire and program.
4. A book to read? Or a friend to drive you somewhere, please don’t constantly look over our shoulders
What I will be providing:
1. Antenna adapter and wiring harness
2. Steering wheel controls adapters
3. Any other relevant wiring, screws etc etc
4. Labor
5. You can also purchase fully authorized pioneer equipment through me if you wish, it will come with full warranty, but pricing won’t be like Ebay.
How to Sign up:
If you are serious about getting it done, reply to this thread with the following information:
1. The year of your G35, Bose or non-Bose, stock nav or non nav. Sedan or coupe…
2. What are you having installed: list model numbers and all the accessories you plan to have installed
3. If you already have some other piece of aftermarket audio related gear installed, please tell me.
What happens from here:
Basically, within the two day time frame, depending on how many accessories people choose to have, I figure we would be able to do a total of 6-8 cars maximum. What I will do is, treat each person who sign up uniquely, and will PM each of you with a total cost. I will also estimate the time it should take for each vehicle and start a tally. Once I see that the total time required has come close to about 16hours (2 days), I will cut it off at that point. It could be as few as four cars, if all of them decided to install tons of accessories, or it could be up to 8 or so straight forward double din installs.
Once you are confirmed on the list, I will need to take a deposit from you of $100, with the rest due upon completion of the install. Each of you will also receive an invoice for your records.
Any questions, please PM me, I would like to keep the thread relatively clear if possible. thank you!
Old Apr 9, 2008 | 02:29 PM
Calvin's Avatar
Overglorified Altima
I wish I had a DD for you to install.
Old Apr 9, 2008 | 02:33 PM
phatbuddha's Avatar
How about tracing down engine noise? Started happening to me about a week ago
Old Apr 9, 2008 | 02:38 PM
16psibrick's Avatar
tracing engine noise is one of the most unpredictable things in car audio, it could take as little as 5 mins, it could take as long as a day, i would hate for you to come and then we have no time to properly diagnose what the issue is i may also not be the best person for that, as in the 70 or so Gs and Zs i have done, i have had ZERO alternator noise issues to date.
if it just started happening to you, what have you cahnged recently? it could be a variety of things, from headunit/amp going bad, to a ground working loose or a cut or shorting rca cable/rca end
b
Old Apr 9, 2008 | 02:42 PM
phatbuddha's Avatar
I'm thinking something came loose. I hit a really bad bump and was like "FVCK!"
I know what a bitch it is, that's why I don't want to do it. For now, I'm living with it because it isn't bad, but I know it's there which is what pisses me off.
Typically I listen to my stereo pretty loud so I rarely ever hear it
Old Apr 9, 2008 | 03:32 PM
im2slpy's Avatar
any discounts for being the first to sign up? haha
1. 2007 G35 Coupe, non-Bose, non nav
2. Pioneer Avic-D3, CD-i200 (ipod), CD-BTB200 (bluetooth).. also like the steering wheel controls retention
3. None
When will this take place?
SN: fadedspiritz
Email: tthai84 (at) gmail.com
Old Apr 9, 2008 | 03:48 PM
EricIsKlumzyee's Avatar
PM me a Price as well as whats a good combo for Audio
I'm looking for a system that has a cool display.. (I have factory Navi so its navigation program is whatever to me) Want something that looks good and most compadible for our cars. Also something thats sounds equal or better then our OEM BOSE system. Also mainly want the ability to play DVDs and iPOD compadibility.
2006 G35 Coupe
Perm. Pacakge (BOSE SYTEM)
Factory Navigation
Sat Radio
Special Notes:
Would also like Rear View Mirror Camera (I have an aftermarket Kenstyle Rear).
Relocate my OEM SAT Antenna to the rear DECK of the car if its re-useable - if not then remove it for me please =)
Steering Wheel Controls
I know your first post, but can you do the DUAL button for me? lol
Thanks
Old Apr 9, 2008 | 04:00 PM
16psibrick's Avatar
if its osmething loose, it couldbe a loose ground or rca, if you want, you can come down and if we have osme time, we can check it out
im2slpy: i will send you a PM in a day or two.
klumzyee: do you have a link to the camera? relocating the factory sat antenna may not have the time for nor may it reach. are you saying you also want to get a unit from me? and for htis unit, do you want just DVD ability or also another nav headunit? I have a friend who is selling a since discontinued (sadly) pioneer 6800 6 disc dvd in dash changer headunit, it looks just like the Z2, but its a 6 disc in dash changer, a pretty nice unit. that may work for you.
dual buttons i just dont do, i am not that good of a soderer, and if i screw up, its two units costing both over 200 bucks ruined. sorry... butlike i said, i think japanparts sells a version that already has the dual button in it, i think its a little bit more cash.
b
Old Apr 9, 2008 | 05:33 PM
WaLLy's Avatar
time to sell one of the cameras of yours
I wish this was a year ago! I would of gotten the DD I wanted... oh well.
Old Apr 9, 2008 | 07:19 PM
phatbuddha's Avatar
I'm not going to waste your time. I already know what a bitch its going to be.
Appreciate the offer though
Old Apr 9, 2008 | 07:59 PM
SIN3's Avatar
04 coupe
looking to get my ipod hooked up.
what do i need to bring and when?
PM ME!
Old Apr 9, 2008 | 08:24 PM
SR20DET510's Avatar
What about single dins? I wil PM you!
Old Apr 9, 2008 | 09:33 PM
16psibrick's Avatar
single dins, if we have time, i can do, but its acutally much more time consuming thn double din...i think twice the time roughly.
sin3. ipod hooked up to stock headunit? or aftermarket?
b
Old Apr 9, 2008 | 09:54 PM
b
From you or you recomend it and I'll go get it =) depending on price. I want DVD (something with a ok-pretty good screen), CD/MP3 Option with a good Display like a good background type of thing going on while the CD is playing, and iPOD.. My SAT antenna is just sitting in the trunk right now lol if you or if you dont have time then its all good..
Let me know =)
Old Apr 9, 2008 | 11:20 PM
16psibrick's Avatar
k, will send you a PM later tonite or tommorow.
b
