Check engine light is on? what do i do?HELLLLPPPPP!
Old May 4, 2008 | 07:21 PM
O HELLA OEM's Avatar
Originally Posted by express705
its going to blow up
lol!!!!
Old May 4, 2008 | 07:32 PM
InfinitSkyline's Avatar
lolz....i just took a dump man...booooom!
Old May 4, 2008 | 08:58 PM
O HELLA JDM's Avatar
^^^ you ur cuzzin is chill man...yea if u want ur roof black let me know i can help u with dat
Old May 5, 2008 | 11:52 AM
Yea he told me that u wer down here bro....i was like...waaaaat? anyway...yea hes cool. Hows tha trunk?
Old May 5, 2008 | 11:55 AM
Here's what my mechanic told me, the code is P0300_multiple cylider misfiring.
Old May 5, 2008 | 12:07 PM
express705's Avatar
thats not good. its gonna blow for sure.
Old May 5, 2008 | 12:26 PM
Deepdiver's Avatar
it might be bad coils or plugs.
Old May 5, 2008 | 01:12 PM
Nismo G's Avatar
LMAO!!!!
It is your spark plugs.
-Sean
Old May 5, 2008 | 02:23 PM
EricIsKlumzyee's Avatar
for that code I'd actually use a scanner to clear it.. if it comes back then see if it specifies which cylinder.. swap coils from the misfiring cylinder to a known good one.. this way you can diag and isolate the problem without any tools..
reason I say clear it is because its not a big deal.. if it was a big deal you'll notice it in your idle. so clear the code and it might just be a fluke that it happened.. but yeah most likely its either cable or coil.. doubt its the plug
actually if you take it to Nissan i'm almost 100% sure they can tell you which cylinder it is
- Eric
Old May 5, 2008 | 02:30 PM
Nismo G's Avatar
- Eric
Good call on just swapping the coils...this way you will know if it is the plug or the coil without having to take the plugs out.
-Sean
Old May 5, 2008 | 02:31 PM
express705's Avatar
clearing codes sucks. i just cleared codes, running rich in bank a and b, and they came back.
stupid ecu
Old May 5, 2008 | 02:34 PM
for you.. better rich then lean I guess? retune? O.o
Old May 5, 2008 | 02:35 PM
express705's Avatar
i just got a tune...
Old May 5, 2008 | 02:38 PM
lolz. ur funny man....i dont want to die!
  #30
express705's Avatar
get a 3 point harness seat belt and a roll cage. youll be fine.
