Wheel/Bolt/Hub Pattern Adapter work for?..
Old May 15, 2008 | 07:42 PM
L7nx's Avatar
Basically I found the wheels ive been wanting BUT there discontinued and not the right size for the G They are 5x112, and I believe the G's are 5x114.3. So , i was told by the seller i can get something called a Wheel/Bolt Pattern Adapter to make them fit? something similar to this
http://www.europerformance.co.uk/pag...sub_category=1
true or not?
The wheels are: Maya STM's Black 19x9.5 / 19x10.5" 5x112 3.5" chrome lip. 32 F/ 38 R offset.
Is this true? possible? safe to do?
Old May 15, 2008 | 08:09 PM
dahkyne's Avatar
what car are they going on? coupe or sedan?
are you lowered? how much camber?
if theyre even available, you can get H+R adapters for the wheels... but you will be extending the offset from the hub about 15-25mm depending on what is offered in terms of adapters, thus making your final offsets go into the high 'teens or low 20s.
if you have a sedan thats lowered, the wheel, combined with adapters will force the wheel to stick out and no amount of camber is gonna fix how that looks . if its a coupe, the adapters + wheels should be fine, as a lot of aftermarket wheels are offered in low offsets for coupes
Old May 15, 2008 | 08:18 PM
L7nx's Avatar
For a coupe
Old May 15, 2008 | 08:22 PM
G37Rider92649's Avatar
hrrrrrrrrrrm honesty my friend I wouldn't do it, and just kick back continue to research and look for more rims, there are too many rims for our cars that fit perfectly, i wouldnt suggest putting the adapters in my opinion....btw what rims did you want?
Old May 15, 2008 | 08:30 PM
L7nx's Avatar
They are Maya STM's. I've always liked them, but being there discontinued, should probably another reason i shouldn't move forward with it.
Old May 15, 2008 | 08:37 PM
gary c's Avatar
Wheel Adapters....?
Naaaa, not a good idea to install wheel adapters! Try going to our Marketplace and do a WTB (want to buy) for the wheels you're looking for.
And do the same thing on My350Z.com, someone has the wheels you're
looking for....G/L!
Gary
Old May 15, 2008 | 08:46 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
^ WHS +1....
JMO but I'd never use them.
EnCr1pt3d
Jul 8, 2019 02:48 PM
Gip
Aug 24, 2015 05:31 PM
DRG35R
Jul 31, 2015 10:23 AM
