anyone local can replace clutch spring or bearing?
Old Aug 23, 2009 | 02:04 AM
ac419's Avatar
i've been reading up lately and i'm starting to think my clutch bearing or spring might need to be replaced.
does anyone know where i can get this replaced without going to the dealership?
thanks
-alex
Old Aug 24, 2009 | 11:48 PM
MEECHIN's Avatar
Are you talking about the spring that's physically on the clutch?
Old Aug 25, 2009 | 12:50 AM
ac419's Avatar
not sure.. all i know is that everytime i step on the clutch pedel.. it makes a squealing noise.. i tried some wd40 tonight.. we'll see if it takes care of the problem
Old Aug 25, 2009 | 01:04 AM
oyoquem's Avatar
What did you spray the WD40 on?
Old Aug 25, 2009 | 01:23 AM
ac419's Avatar
i sprayed it on the back of the clutch pedal.. and almost all metal parts where any lube might be needed. i think i sprayed almost everything except the wires and the fuse box.. lol
Old Aug 25, 2009 | 01:46 AM
oyoquem's Avatar
So is the noise coming from the clutch or the clutch pedal area?
Old Aug 25, 2009 | 01:53 AM
ac419's Avatar
it was from the clutch pedal area, but i sprayed the behind the pedals, and all the joints underneath where screws and nuts are
after a test drive.. clutch pedal much smoother and no squealing noises
Old Aug 25, 2009 | 02:07 AM
oyoquem's Avatar
i think it was the pedal area.. i sprayed the clutch engagement pin and didn't do anything
The slave cylinder should be greased with lithium based grease. It is made to handle high temperature. I believe WD40 hardens when exposed to high temperatures. It should be ok on the pedal parts but I would still use some grease on that as well.
Old Aug 25, 2009 | 02:08 AM
ac419's Avatar
where is the slave cylinder?
Old Aug 25, 2009 | 02:10 AM
oyoquem's Avatar
Its the part that moves the clutch fork. It is attached to the outside of the transmission.
Old Aug 25, 2009 | 01:03 PM
MEECHIN's Avatar
the squeaking resonates thru the pedal and makes it seem like it's the pedal.
but in fact it's just like how it was stated above by Oyoquem.
Old Aug 25, 2009 | 01:11 PM
ac419's Avatar
yeah i'm not too good with these things.. sprayed wd40 and the sound is gone.. probably quick fix.. but i'll need to eventually put the greese sooner or later
Old Aug 25, 2009 | 04:38 PM
1SlowSedan's Avatar
What kind of grease are you suppose to use?
Old Aug 25, 2009 | 05:13 PM
ac419's Avatar
it's called lithium greese. it can be found almost everywhere.. home depot, kragens, etc etc.. usually comes in a tube.. costs around $3-7
Old Aug 25, 2009 | 06:38 PM
oyoquem's Avatar
I use Mobil 1 synthetic grease. Its lithium based
EPG35
Aug 16, 2015 04:52 PM
socalg35x
Jul 28, 2015 10:42 AM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
itschuckster
Jul 25, 2015 08:07 AM
