HELP JWT Clutch flywheel question..!!!
Old Mar 4, 2010 | 02:54 PM
heythatsneat's Avatar
Originally Posted by tastefullydone
^^ Yeh, you can hear it at idle a little bit and when you're in first gear between 1k until 2k rpm, only for the split second that the engine is in that range you hear the chatter cuz most people when cruising in first gear will be well above 3000 rpm so it really is for maybe .25 of a second you hear the click. Once your up in late first gear (past 3000 rpm) you'll never hear it again cuz from that point on every time you shift to 2,3,4,5, and 6 your revs will not drop into the 1000-2000 range chatter range.
good info. im going with the jwt setup and i have been looking for what you just said for the past 3 weeks!! life saver!
Old Mar 4, 2010 | 07:31 PM
TastefullyDone's Avatar
glad to help.noble choice, you will like. promise. Enjoi.
Video Share
Jan 31, 2017 04:00 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
bigmike
Sep 17, 2015 01:58 PM
