I need someone experienced with wiring & soldering..
Old May 22, 2010 | 09:01 PM
Choleaoum's Avatar
Hey guys, I fried a relay from probing my BCM and my driver door won't lock anymore. I was wondering if there was anyone here local that could help me replace the relay for not too much. I would do it myself but I don't trust myself with a soldering gun and I'm not too familiar with the BCM.
It shouldn't be too hard to replace the relay on the circuit board.
Old May 23, 2010 | 02:44 AM
pythonjosh's Avatar
I can take care of that for ya. To verify that it is a relay, both door lock actuators are not working right?
If one actuator is working and the other is not, your relays are fine.
If the actuator is bad, I've hooked up a few members with universal door lock actuators:
https://g35driver.com/forums/souther...cks-fixed.html
I do soldering too. But I will investigate what is and isn't working in the door locking system. I'm up in Torrance on Hawthorne.
Old May 23, 2010 | 02:49 PM
Choleaoum's Avatar
Sounds good! All the doors UNLOCK just fine, but when I press the lock button it will lock all my doors except the driver. I have a Matrix 50.5x Two-Way Pager and I accidently sent a 12volt to a wire that caused my driver door to stop locking. ( I forget what wire, I was trying to find the lock/unlock wire only to find out that it was because I didn't set up my alarm to send two pulses LOL. ) I hate working with cramped spaces.
Unless someone in the forums will be kind enough to lend me there BCM for 2 seconds to find out if it is my BCM lol rather then my actuator.
Old May 23, 2010 | 03:02 PM
pythonjosh's Avatar
All you gotta do is get to the purple and blue door lock wires behind the speaker and stab them with a hot wire tester and lock/unlock the doors. If it lights up, your BCM is good and the actuator died. Both positive and ground should be tested as the 2 wires alternate depending on lock or unlock.
If it's the actuator, I have a cheap fix for you. If it's the BCM, I'd recommend replacing it. Since the other doors work (sedan?) I don't think it is the BCM.
Old May 23, 2010 | 03:31 PM
Choleaoum's Avatar
I wish I had a BCM to test lol.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
9tray turbo
Sep 29, 2015 10:22 PM
vamarris
Sep 26, 2015 12:56 PM
