broken lugnut on stud help!!
Old Jul 15, 2010 | 02:02 PM
xRayZx's Avatar
Originally Posted by Sonny35
wholey! how da phuc you did that?...
You mean how i get the lugnut break in there like that? I was just tightening the nut with my hands. i didnt even kick it or anything. must've been the rust so it got weakened
Originally Posted by MEXTEP
I pmed you my cel ..I will talk to Pollo later today and see how loaded he is with work...they open after 6pm
sorry, i didn't get your PM. resend?
Old Jul 20, 2010 | 02:15 PM
xRayZx's Avatar
So last night, i took my car to R&J in Carson. After 2 hours of chiseling, Ralph (the mechanic) FINALLY got the broken lug nut off!! Every other shop I went to wasn't able to do it. But he did it! The price was also unbeatable. The failed shops were charging me $200. Ralph charged me $120.
Yea, just letting you guys know whats up. After 7 months of unable to remove the wheel.
Old Jul 20, 2010 | 04:37 PM
MEXTEP's Avatar
Pollo can now carve out freakin statutes after all the chiseling he had to do on that Lugnut.
Old Jul 20, 2010 | 04:49 PM
GR6RR's Avatar
LOL^
daym, must of been some chit!!,... glad you got it off though...
Old Jul 20, 2010 | 06:16 PM
G SEDAN's Avatar
R&J does it again!!!
Old Aug 2, 2010 | 12:24 PM
Killjulez's Avatar
haha wow. I ran into this a little late. i had to do this on my g last weekend. Same exact problem... my friend used an impact to tighten my lug and it would not come off. Ended up just taking a chisel to it for awhile along with a drill. Rim got pretty beat up, and so did the chisel, but at least i got my rim off. Glad you were able to fix this horrible problem, one of the worst things i have had to fix...so much hammering
Old Aug 2, 2010 | 01:58 PM
MEXTEP's Avatar
The problem R&J had was because OP had already tried to chisel it out..so there was only a small area that was impeding the process.
Old Aug 2, 2010 | 02:03 PM
gte959s's Avatar
20 Year Member
You could try and take it some where like a tire shop where they can put it on a lift and cut it off from the other side of the hub. You would have to get a new stud, but you probably need that now anyways.
Old Aug 2, 2010 | 02:11 PM
Killjulez's Avatar
That's exactly what happened to me. First started chiseling to get to the stud, then drilled, then I just kept hitting the stud with the chisel until it broke all the way through. took about an hour and a half. those nuts are not made to shatter at all, the metal just folds over itself.
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
the93owner
Oct 4, 2015 09:40 AM
w4kj4k
Oct 2, 2015 07:57 PM
