Who's running TPs here in SoCal?
Old Nov 4, 2010 | 09:20 PM
juan350gt's Avatar
I dunno man lol GReddy has better exhaust than that TT exhaust.. like the Evo 2 sounds sweet. but Greddy TT exhaust with resonated kinetix test pipes lol man it sounds horrible bro and people at the meet just tell him it sounds ok but they really don't like it cause it sounds of V6 Rustang.
Originally Posted by iwant2drift
Damn that sounds like a horrible setup, wonder why he would do that
Old Nov 4, 2010 | 10:34 PM
whoisthis's Avatar
"Think Green"
Old Nov 5, 2010 | 02:15 PM
KingCobra's Avatar
^ can you install my test pipes
LOL
Old Nov 5, 2010 | 02:41 PM
The Stimulation's Avatar
Installing test pipes isn't too hard, but removing the OEM cats is a bit difficult. You'll need some long extenders and a lift REALLY helps. I tried putting on my OEM cat and said fug it, took it to the muffler shop. They should be able to do it for $80 give or take on the one you go to.
Old Nov 5, 2010 | 02:44 PM
KingCobra's Avatar
Yup sounds good, wasn't gonna try either way since I don't have the tools or a lift lol
Hopefully should have it done this weekend...
Old Nov 5, 2010 | 03:44 PM
whoisthis's Avatar
LOL
I neva installed TP before. But installed Y piipe
Old Nov 5, 2010 | 04:13 PM
Jairen's Avatar
It's really not hard to install test pipes. Just make sure you soak the nuts and bolts on the OEM cats AND bracket with some penetrating lube. Long extensions and some muscle and it will go. It also helps to have an 02 socket, but you can use an open ended wrench. I have access to a lift and it only took less than an hour taking my time.
Old Nov 5, 2010 | 05:21 PM
KingCobra's Avatar
^ lucky you have access to a lift...
Old Nov 6, 2010 | 05:47 PM
whoisthis's Avatar
When i installed Hr y-pipe on DE engine, i used the 3 piece OEM gasket instead of 1 piece hr y-pipe gasket. I think i have exhaust leak was i suppose to use the 1 piece?
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
dorkstar
Engine - Exhaust
Sep 9, 2015 07:43 PM
n2fooz
Sep 4, 2015 07:46 PM
G35CO
Sep 4, 2015 09:27 AM
