Streetimage - Tein Flex Special.
Old Dec 2, 2004 | 02:24 PM
jim@streetimage's Avatar
If you wanted some new suspension for your G or Z this is the time because the price is right =). We do not have many on hand so once these sell out we are not sure when we can get some more in.
- You also come by our shop and pick them up. So that you do not have to pay for shipping.
- Tein Flex : 1530+Shipping
- Edfc : $320
**If you are paying via c.c. you'd need to add an additional 3% to cover the surcharges.**
***We also can do the install for you**
Here is also some info on the Tein Flex :
TEIN Type FLEX damper kit was designed to provide driving comfort and sports performance with its full-length adjustment system. We have incorporated separate height and preload adjustments, which allows you to have various set-ups to meet different road conditions. The FLEX Damper kit includes pillow ball upper mounts and is compatible with the EDFC, for maximum performance for the streets.
* Full-length adjustment and height adjustment for separate setting of the height and spring preload.
* 16 levels of damping force adjustment (compression and rebound together).
* Teflon coating for rust prevention.
* Newly designed spring seat and spring seat lock for easy height adjusting.
* Pillow ball upper mounts are included.
* Compatible with EDFC.
* Available for overhaul.
Old Dec 3, 2004 | 02:32 AM
RashMan1450's Avatar
HEy check PM
Old Dec 3, 2004 | 03:25 AM
PM Sent .
Old Dec 4, 2004 | 11:10 PM
**Bump** **Bump**
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
bigmike
Sep 17, 2015 01:58 PM
twentyeggs
Sep 11, 2015 03:58 PM
