Help on 06-07 OEM Projector Headlight Fog light HID Installation !
Old Jun 18, 2011 | 02:19 AM
gradybear's Avatar
Does anyone know if there is any vendor or person who is willing to do the HID installation for 06-07 projector headlight's fog light (Bulb size H1) ?
After I did some research for it, it is hard for me to do it.
So I am looking for someone to do it for me.
My location is close to Diamond Bar, Walnut, Rowland Heights, and Chino Hills.
Please let me know if you know anyone or any vendor is close to these areas.
I really wanna put on HID for my fog lights (the one on the headlights).
Thank you
Old Jun 18, 2011 | 12:17 PM
MEXTEP's Avatar
Thank you
R&J in Carson is open later today (around 3)
645 219th St
Carson, CA 90745
You can text me and I can get you price and appointment
JAmes
310-874-8731
Old Jun 18, 2011 | 12:32 PM
gradybear's Avatar
645 219th St
Carson, CA 90745
JAmes
310-874-8731
Thank you for your attention.
But it is too far away from my place, it is about 37-40 miles of driving.
I am looking for someone or any vendor that's close to city of Diamond Bar, Walnut, Chino Hills, or Rowland Heights.
Thank you tho
Old Jun 18, 2011 | 12:39 PM
B L U E S L A T E's Avatar
Honda Accord
Putting HID is easy... it's just plug and play...
All you have to do is find the place to mount the ballast, plug in 3 connectors together, and put in the bulbs. That's it.
Old Jun 18, 2011 | 12:52 PM
gradybear's Avatar
For my fog lights, there is a flat head wire (positive and negative wire combined) connected to my H1 bulb.
My friend told me that I have to find the original positive and negative wires which is on the other side of the headlight and cut it from there then rewire them, so I will have the negative and positive wire for the HID.
That's why I do not know how to do it myself.
Do you know how to do it ? Like a DIY step by step ?
Anyway, Thank you for your advice
Old Jun 18, 2011 | 01:31 PM
ON's Avatar
ON
The easiest way to do it is to use the wires coming out of the fog light cap. There are three wires coming out of the fog light cap: Black, Yellow, and Yellow/Green. The black is negative, and the other two are positive. You want to tap into the Yellow wire, as that wire is for you fog lights. The yellow/green wire is for the little bulb that is always on. So don't tap into that one unless you want your HIDs to be on all the time.
Old Jun 18, 2011 | 05:18 PM
gradybear's Avatar
Thank you for your info
Should I cut the wire outside of the cap or from inside ?
Do you know what else I need ? Like what other stuffs I need to purchase before the installation ?
Really appreciate for your help
Old Jun 19, 2011 | 11:19 PM
Zioxx's Avatar
Not that hard bro trust me. I have mine done, its just plug and play. The H1 oem bulb we have is just connected to a positive and the negative wire is connected I believe to the chasis. no need to cut anything!
Old Jun 20, 2011 | 12:18 AM
gradybear's Avatar
Really ? Because I was looking at it online and they combined the positive and negative wires together then connected to OEM bulb.
Shouldn't I get the power from those wires to my HID ballast then connect to the HID bulb from the other wire that come along with the Kit ?
Jusseth
Sep 13, 2020 12:25 PM
nickmcc123
Lights
Oct 7, 2017 12:18 AM
bTanz
Oct 15, 2015 02:31 PM
nickmcc123
Jul 29, 2015 05:14 PM
attarday
Jul 15, 2015 04:03 PM
