SoCal shop to pass emissions
Old Jan 13, 2014 | 01:36 PM
g06driver's Avatar
So I have a set of high flow cats on my car no check engine light or anything like that but the cats themselves do not have the CARB numbers stamped on the bottom that are needed for the inspection. Anyone know any shops that will overlook the visual part? It technically passes smog emissions, just not visual. Thanks.
Old Jan 13, 2014 | 03:17 PM
irishsig's Avatar
I go to Smog Only in Glendale. He never checks under the car.
I didn't pass the 1st time because of the HFCs, I had to put the oem cats back on and finally passed.
Smog Only
456 W Colorado St. Glendale, CA 91204
(818) 244-6644
Old Jan 13, 2014 | 03:28 PM
g06driver's Avatar
Cool thanks. I'm not originally from California so smog is done every 2 years is there anything else that needs to be done? The "smog only" kinda threw me off. Thanks again.
Old Jan 13, 2014 | 04:39 PM
irishsig's Avatar
No, They just put the sniffer for the smog check in the tailpipe and run it through it's gears.
But if you have HFCs you probably won't pass, the numbers for the allowed emissions will most likely be too high.
It was for me, so I had to put the oem cats back on and then went back to the same place and passed.
Here were my #s with Berk HFCs the 1st time.
Old Jan 13, 2014 | 05:21 PM
g06driver's Avatar
Well I have the stock cats worst case...but I got the newer kinetix HFCs that are supposedly smog passable they just don't have the CARB number needed for the visible inspection part of it. Thanks for your help.
Old Jan 22, 2014 | 09:02 PM
gary c's Avatar
Don't be fooled by the above posts! CA. has the new STAR system and requires more than just the sniffer test. They visually go over your car, even after market intakes won't pass without a CARB sticker. HFCs won't pass because there isn't one that's legal in CA., they won't pass the sniffer test! You need to swap the OE cats back on, drive your G for 25 miles and then take the test which you'll pass unless you have error codes.
Gary
Old Jan 22, 2014 | 09:52 PM
hurleyguys's Avatar
ya what gary said. i had HFC's on my car and it was no where close to passing the sniffer test.
Old Apr 11, 2014 | 08:30 PM
MEXTEP's Avatar
Someone in the Inland Empire that does the "special smogs"? for my sedan
shoot me a text 310-874-8731
Old Apr 11, 2014 | 08:44 PM
bluedevils95's Avatar
Looks like i will be coming to you for that when the time comes
Old Jun 6, 2014 | 03:17 PM
dsgb73's Avatar
Veteran: Navy
Didn't they pass a law in 2013 that starting in 2014 the sniffer test would no longer be required? The shop I took mine to last year was a STAR station and I swear I remember him saying that the sniffer would no longer be done but that they will start doing the OBD II scanner for a more comprehensive check and if there are any codes present, than you would fail. I could be wrong so don't quote me verbatim and please find out for yourself if this is indeed true. Problem though is that most HFCs will give off a smell anyway and if the tech is smart, they'll probably pick up on it rather quick. I have a custom exhaust, stock intakes and put the stock cats on before getting my smog.
Old Jun 6, 2014 | 03:50 PM
Deepdiver's Avatar
sub'd for future reference
Old Jun 6, 2014 | 03:55 PM
Hotdawwgman's Avatar
me 2. I want to get ART pipes but need to smog my G first!
Old Jun 6, 2014 | 06:12 PM
dreloc's Avatar
What do you mean by "special smogs"?
Old Jun 6, 2014 | 10:08 PM
El Nino's Avatar
If it indeed is sniffer free; I no longer have to worry about smogs
Old Jun 7, 2014 | 03:02 PM
irishsig's Avatar
HFCs don't give off any smell, you're probably thinking of test pipes.
Either way you won't pass with either TPs or HFCs.
I'm not aware of any new law that does away with the sniffer test.
California legislation would never allow that because it would cost them revenue... greedy a-holes.
Just had my smog done last month and they did both sniffer and OBD II scan.
seagrasser
May 3, 2022 09:43 AM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
Albanian122
NorthEast
Sep 28, 2015 03:03 PM
lag35driver
Northern California
Sep 17, 2015 12:32 PM
