ECM Repair shop needed
Old Oct 13, 2016 | 12:22 AM
hrabini's Avatar
So I have determined the ECM in my 2004 g35 sedan is fried. and ive found that trying to find another with same code number is difficult at best. adding to that issue is that the ECM replacement unit will then need to be programed to my car.
Best bet is to have it repaired by one of many that I found on line, however... who is to be trusted?
Any recommendations would be appreciated.
Thanks,
Old Oct 13, 2016 | 03:17 AM
Blue Dream's Avatar
I drove ttrank's car solo
Hit up Shawn Church at Church's Automotive in LA. If he can't do it, my guess he can point you in the right direction.
Old Oct 27, 2016 | 04:26 PM
hrabini's Avatar
My ECM was not repairable, so I finally sourced a replacement with exact same part numbers. So If I understand this I will need to first have it programmed by a locksmith so my key will work. Then after that I must do the following
1ECM reset
2Accelerator pedal position learning
3Throttle valve position learning (which I have done in past when TB went bad)
4Idle air learning
Will it need to learn anything else?
Old Oct 27, 2016 | 04:51 PM
bluedevils95's Avatar
When i had mine replaced i did it myself. Church automotive just reloaded my settings from the last ECU that he had stored on his computer. Everything worked out fine.
Old Oct 27, 2016 | 05:49 PM
hrabini's Avatar
Thing is they wont program to key... so that still needs lock smith.. so my question stands... if after I get the mobilizer to function with original key...are there any other steps besides the bellow to get my car to run normal again...
1ECM reset
4Idle air learning
JMFeld02
Steering & Suspension
Aug 11, 2016 09:06 PM
MilesToInfiniti
Jul 27, 2016 12:46 AM
zcherub
Jul 26, 2016 10:54 PM
Black_Out
Jul 23, 2016 08:31 PM
G-MAN (CANADA)
Canada
Jul 20, 2016 12:30 PM
