GTSpec Chassis/Suspension Braces on sale!
Old Aug 31, 2006 | 09:32 PM
partshipperdave's Avatar
Exclamation GTSpec Chassis/Suspension Braces on sale!
PartShippers.com are proud to offer the g35driver.com community this sale on the outstanding GTSpec line of chassis and suspension products.
http://www.partshippers.com/index.ph...ord=GTSpec+G35
We have the complete line of chassis/suspension braces in stock and ready to ship!
FRONT AND REAR LOWER TIE BRACE - Fits Coupe and Sedan
REAR LATERAL ARM BRACE - Fits Coupe and Sedan with True Dual Exhaust
MID CHASSIS REINFORCEMENT BRACE - Fits Coupe only
Thanks for your support!
Old Sep 13, 2006 | 10:08 PM
Sales still going on, and an ADDITIONAL 5% OFF the front and rear lower tie braces for the month of September. Get 'em while they last! hot item and great mod!
Old Sep 19, 2006 | 04:17 AM
TedRuxpin's Avatar
will the mid chassis reinforcement brace fit if i have a JIC Y Pipe?
Old Sep 19, 2006 | 09:06 PM
Hey - yeah, it should clear no problem. It's designed to clear the stock exhaust, so it'll be fine. The only bar that has clearance issues is the rear lateral arm bar. That will only clear a True Dual exhaust system.
Old Sep 22, 2006 | 03:57 AM
AboostedG's Avatar
Will any of this work with a Powerhouse Amuse Exhaust, Japtrix Y-Pipe, and Kinetix Race Pipes?
Old Sep 25, 2006 | 10:55 PM
hey AFitchTLS - the front and rear lower braces, no problem. The mid chassis brace would be fine too. The rear lateral arm brace should also clear the Y pipe without any issues. I have not had direct experience with a fitment install on that specific setup, but GTSpec states that the rear lateral arm brace will work as long as it's a true dual exhaust setup. hope that answers your questions.
Thanks for the interest!
Old Sep 26, 2006 | 02:16 AM
Alius_G's Avatar
Will the Mid Brace will clear the Amuse Y-pipe?
Old Sep 26, 2006 | 11:34 AM
04Gwhiz's Avatar
will the front tie brace clear a kinetix ssv and an seibon cf js hood?
Old Sep 27, 2006 | 10:12 PM
hey guys - the mid chassis brace should be fine with the amuse y-pipe. the clearance with that pipe installed is not much different from the stock setup.
The front tie brace, I'm assuming you mean the front strut tower brace?? The clearance of the GTSpec front strut brace is similar to the stock one, since it has such close tolerances under there. If your stock brace is fitting on there now with that hood, then this would should be ok too.
It's hard to gaurantee perfect fitment when you start mixing aftermarket products, but all the GTSpec braces were designed with this concept in mind, in addition to the obvious consideration to clear stock configurations.
Old Sep 27, 2006 | 11:11 PM
drunkin master's Avatar
Where does the lower front and rear tie brace go?
any pictures with those installed.
How do we get the 5% discount?
Do these fit the 350z
Old Sep 27, 2006 | 11:16 PM
Hey, see the attached pics for install examples from a customer's car.
The 5% discount is already applied to our pricing on our site, and yes, the definitely fit on the 350Z also!
Thanks for your interest.
Attached Thumbnails GTSpec Chassis/Suspension Braces on sale!-ryancar-008.jpg   GTSpec Chassis/Suspension Braces on sale!-ryancar-009.jpg   GTSpec Chassis/Suspension Braces on sale!-ryancar-010.jpg
Old Oct 11, 2006 | 08:52 PM
sale still available for the all the braces from GTSpec! Thanks for the recent orders everyone.
Old Oct 19, 2006 | 11:41 PM
Alan's Avatar
quick question. whats the difference between the tie braces and the rear lateral arm brace?
Edit: also does these pieces clear hks exhaust on a coupe? my guess it does since it is true dual but i just wana be sure
Old Oct 22, 2006 | 01:43 PM
The tie braces and the rear lateral arm brace all work to help stiffen the chassis from unneccesary flexing or twisting under "spirited driving" conditions. the rear lateral arm brace will clear the TD exhaust, and the pic above shows the mounting location for it. There is also a few pics above showing the tie braces too.
They're all in stock and ready to ship!
Old Oct 22, 2006 | 04:08 PM
enzotsg's Avatar
cool
