The Richie Front Strut Bar Group Buy!
Old Feb 6, 2007 | 09:58 PM
richie's Avatar
Originally Posted by aHero4Eternity
i would assume not much..you said it touches the hood insulator, right?
mine touches the insulator slightly
Old Feb 6, 2007 | 09:59 PM
dreamweaver's Avatar
am i reading this right? this wont fit a SC car? do you mean a stillen SC... because my Vortech looks like it wouldnt interfear? damm id order one if it would work...
Old Feb 6, 2007 | 10:48 PM
richie's Avatar
yes, it will not work with the stillen SC
for the Vortech, I think it would fit. It fit over the AEM CAI....the Vortech pipe looks like it has the same curve/size as the stock tube. Do you still have the stock engine cover on? If so, as long as the Vortech piping is at the same height as the engine cover, then it'll fit.....if you look at the second to last picture in this thread, there is ample space between the bar and the stock tube.
Old Feb 7, 2007 | 12:37 AM
baileyrx's Avatar
how does it attach to the shock mounts?
do you have to drop the any bolts or can you simply remove the stock nuts place this on & rebolt?
Old Feb 7, 2007 | 03:17 AM
richie's Avatar
it attaches right on top of the shock mounts. you don't have to drop any bolts, just simply remove the stock nuts and place the tower brackets on and rebolt.
Old Feb 7, 2007 | 03:57 AM
cloud's Avatar
will this bar clear the 5/16 spacer with the engine cover on?
Old Feb 7, 2007 | 04:19 AM
richie's Avatar
mmmmm, haven't tried that variation yet... but this is what it looks like with the 5/16 spacer without the cover
I'll have the driver take some pictures of the clearance between the bar and the plenum, then maybe you can gauge whether or not the cover is doable too.
Old Feb 7, 2007 | 10:24 AM
tkman00's Avatar
i'm really interested, let's see some sedan pics.
Old Feb 7, 2007 | 11:21 AM
Brando's Avatar
Cool
The question on the Vortech fittment is with clearing the square block for the MAF connection.
I'm still not sure if it will clear......any test cars available out there???
Why can't I attach a pic?
Old Feb 7, 2007 | 11:32 AM
gary c's Avatar
Would like one but............
Since I have the MotorDyne 1/2" spacer I seriously doubt your strut bar
would fit........damn!
Old Feb 7, 2007 | 11:34 AM
brianmfournier's Avatar
gary c, the crawford plenum is the equivalent of the 1/2 inch spacer, no? I have the crawford and want to know if this will fit also. Anyone?
Old Feb 7, 2007 | 01:20 PM
Gilley's Avatar
I don't know if it will hit the MAF housing with my Vortech.
Old Feb 7, 2007 | 01:23 PM
Nismo G's Avatar
Just take your MAF housing and turn it so that the actual sensor points towards the plenum...it doesnt have to be right where you have it.
-sean
Old Feb 7, 2007 | 01:26 PM
machavez702's Avatar
I had to do that with my VRT brace, turned the MAF out of the way.
Old Feb 7, 2007 | 01:31 PM
  #30
Nismo G's Avatar
how come we cant attach pictures?
-sean
