The Richie Front Strut Bar Group Buy!
Old Feb 8, 2007 | 01:08 AM
  #61
machavez702's Avatar
Originally Posted by godmans
I guess I will explore on where it will rub on the sedan; since I know that alot of people is hesitant on getting a VRT struct bar for the sedan since there are reported cases of rubbing between the struct bar mounting brace and the AC line.
Please check your pm btw
I have the VRT + 5/16" spacer - engine cover on my sedan. No rubing issue with the lines but it does touch the liner of the hood. I'm interested in this bar because it is inline with the towers rather than canterlevered out past the towers. It probably doesn't make a difference in performance but I'm still interested in this piece. I would suggest that any buyers consider a lower tie bar as well to completely box in the frame, top & bottom. For those who don't know what the "feel" of a stb is like, I compare it to changing from worn tires to new tires, the car just handles better and is more responsive.
BTW, nice looking welds and brackets.
Old Feb 8, 2007 | 01:32 AM
  #62
TwinTurboZ's Avatar
Payment sent!
Since I am local let me know if I can get mine earlier on a pick-up. Perhaps at a meet? Thanks
Old Feb 8, 2007 | 05:07 AM
  #63
MyLilBlkG's Avatar
payment sent!
Old Feb 8, 2007 | 05:36 AM
  #64
Chrome's Avatar
Full payment sent.
Old Feb 8, 2007 | 07:42 AM
  #65
tkman00's Avatar
yeah i'm still really tempted, but the rubbing on the sedan kinda bums me out. can we see pics of said rubbing?
Old Feb 8, 2007 | 08:36 AM
  #66
ma_sha1's Avatar
Full payment sent.
Old Feb 8, 2007 | 09:36 AM
  #67
godmans's Avatar
Full payment sent; please check your pm
Old Feb 8, 2007 | 09:38 AM
  #68
Gilley's Avatar
If you are concerned about the AC line rubbing, wrap it with a small piece of hose and a zip tie.
Old Feb 8, 2007 | 09:45 AM
  #69
richie's Avatar
here is a pic of the rubbing and the workaround. This is the 1st sedan we installed/tested on, want to get another one in so we can confirm it the issue.
Old Feb 8, 2007 | 09:46 AM
  #70
godmans's Avatar
As soon as I recieve the bar, no matter it rubs or not; I will work sth out and report back =)
Old Feb 8, 2007 | 11:34 AM
  #71
SFLG35's Avatar
FGC President
do we know if this clears the crawford plenum yet??
if so ill send my deposit
Old Feb 8, 2007 | 03:10 PM
  #72
v3n0m's Avatar
So the bar uses the shock mounts, correct? Just wondering (I've never done any work like this before), when you remove the stock nuts and bolts from the mounts, do you have to jack up your car first to remove any pressure on the shocks, or can you just do it with the car on the ground?
Old Feb 8, 2007 | 04:12 PM
  #73
richie's Avatar
yes, the bar will clear the crawford plenum, as long as you are not using the engine cover...please check first post for payment info and also PM me once you have sent your deposit/payment....thanks
yes the bar mounts onto the stock mounting points...for all of the installs that we've done, we have never had to jack the car up...
Old Feb 8, 2007 | 04:36 PM
  #74
Gilley's Avatar
You wouldn't want to jack up the car to install the brace.
Old Feb 8, 2007 | 06:16 PM
  #75
richie's Avatar
yea, jacking up the car might cause the strut bolts to drop....
BUMP!!! come on people, we are half way there!!
