Nothing But the Best Suspension Ohlins, KW,HKS
Old Feb 27, 2009 | 08:19 PM
gruppe-s's Avatar
Former Sponsor
Ohlins DFV
Ultimate Track Suspension
Nissan - 350Z - Z33 - F:10 R:7 kg/mm
Priced Super Low. Pm for Price
KW V3
Used by some of the top drift team in the world. During manufacturing of KW Coilover suspensions, the highest quality materials are used to produce individual suspension solutions that enable customers to adjust vehicle height according to their wishes and needs. With this variety, KW Coilover suspensions in Variants 1, 2 and 3 can meet the exact requirements of every customer. The complete systems including high-quality yellow springs, purple aluminum components and Elastomer bump stops with integrated dust protection system, provide a unique comprehensive solution for a personalized vehicle suspension system that meets all performance and quality demands.
Function:
• Infinitely adjustable within german TUEV-tested adjustment parameters
• Shortened struts for increased spring travel
• Trapezoidal threads for simple height adjustment
• Three different damping technologies for individual adjustment
• Elastomer bump stops with integrated dust boot protection
• Easy to read documentation
• Ready to use comprehensive solutions
• Visually perfect – safe and unique motion dynamics
Quality:
• Strut housings in inox-line stainless steel technology
• Anodized aluminum spring collars and add-on pieces
• High-quality, high-tensile racing springs
• Special ventilation and sealing system
• High-quality damping components
• Hardened, chromium-plated piston rods
• Special guide and sealing systems
• Pistons with V-shaped Teflon seals – optimal sealing with minimal friction – temperature-resistant, durable damping technology
Price too Low To Post. $PM For Price
HKS Hipermax 3
Best Ride Quality
HIPERMAX III
Series Concept: Designed and tuned for street application / daily driving.
With the Hipermax III suspension series, the driver gains increased wheel control with improved performance of all vehicle dynamics and increased driver command in all conditions. Hipermax III combines track-quality control with excellent ride and handling characteristics at real-world street speeds. HKS' all-new Hiper Linear Piston Fluid Channel System damping system creates a positive relationship between piston speed and damping force, making it possible to produce a suspension that provides track-level control and feedback with exceptional ride quality at the same time.
Key Features:
• Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements. As piston speed increases, dampening rate linearly increases.
• Strengthened rubber upper mounts – enhanced durability
• Monotube design
• Shock-body length adjustable (most applications)
• 65mm diameter springs – Cold wound and manufactured in-house at HKS to ensure quality and consistency
• Stainless lock nut & ride height adjuster – feature anti-rust & corrosion characteristics for enhanced durability.
• 30-way adjustable dampening
HIPERMAX III SPORT
Series Concept: Designed and tuned for competition / track.
The Hipermax III Sport series has firmer spring rates and valving to take advantage of the smoother, more consistent pavement of race tracks allowing quicker, more precise transient response and instant direction changes necessary in competition. In addition, the Hipermax III Sport incorporates HKS' all-new Hiper Linear Piston fluid-channel system, shock-body length adjustability (most applications) and ultra-thick chrome plating of the cylinder shaft for excellent durability and reduced stiction (static friction). Spherical bearings, for precise steering and feedback, are standard - but reinforced, rubber upper mounts are available for those seeking reduced vibration from less-than-smooth pavement.
Key Features:
• Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements.. As piston speed increases, dampening rate linearly increases.
• Pillowball upper mounts standard
• Monotube design
Hipermax III
$PM For Price
Hipermax III Sport
$Pm For Price
Apexi EXV Dampers
Super Affordable
The N1 ExV Damper is the newest edition to our high performance street line of coilover suspension. The Expert Type V (ExV) is a full coilover suspension featuring a threaded base for precise ride height adjustment without compromising shock or spring travel. We have taken our street suspension to the next level for 2005 by including high performance upper mounts and 32 way ride quality adjustment for street cars that are used at the track as well. The spring rates and internal valving of the ExV has been completely refined for excellent ride quality and sports driving. The ExV was designed to cater exclusively to US market vehicles. With this in mind, internal components have been specifically engineered to withstand harsher road conditions and increased wear caused by everyday street driving. The Expert Type V was developed based upon user requests for a high performance damper that doesn't carry a typical racing suspension price tag. This system stands as our commitment in providing our customers with the ultimate in quality and affordability.
$975 Shipped
Buddy Club D1 Spec Dampers
$1099 Shipped
Buddy Club Racing Spec Dampers
$1099 Shipped
SPC Camber Kit
All Competitors Beat
The SPC Adjustable control arms you can finally tune camber and caster .
SPC Performance's new arm/shim kit has more than enough camber and caster change to correct cars that have been lowered, or for vehicles used in drifting, allowing for precise changes when fine tuning suspension alignment angles necessary when racing or drifting.
The hub and caliper shims extend out the center of the wheel making it possible for the forged and fabricated arm to make up to 5 degrees total camber change and ¡¾1.0¡Æ degrees of caster change.
The SPC Rear Control Arms are the perfect kit for the lowered Z, whether you are looking at high performance, racing, lowered, or extreme applications.
This kit provides plenty of adjustment for camber and toe. With the adjustable EZ Arm?camber can be changed up to And the kit comes with a larger offset toe cam to bring the toe angle back into range.
Front Arms
$450 Shipped
Rear Arms
$235 Shipped
F&R Combo
$675 Shipped
Eibach Lowering Springs
1.2"/1.2" Drop
$250 Shipped
Tein Lowering Springs
S. Tech
.7"/.6" Drop
$250 Shipped
***Open Box Display Sale-1 Set Each in Stock***
H. Tech
.3"/.2" Drop
$250 Shipped
Tanabe Lowering Springs
NF
1.2"/1.2" Drop
$195 Shipped
GF
1.0"/1.2" Drop
$195 Shipped
Old Feb 27, 2009 | 08:34 PM
lekker_droom's Avatar
Damn nice stuff...first three anyway.
Old Feb 28, 2009 | 02:27 PM
truexh's Avatar
Price for SPC Camber Kit F&R Combo to 95824 please
Old Mar 1, 2009 | 12:49 PM
G35-M6's Avatar
how much for eibach pro-kit for 03 g35 coupe shipped to canada? can you ship by usps?
Old Mar 2, 2009 | 09:09 PM
gruppe-s's Avatar
Former Sponsor
truexh the SPC combo is $720 shipped with tax.
G35-M6 the Eibach Pro kit via USPS is $295 shipped to Canada.
Thank you
Old Mar 3, 2009 | 02:40 AM
xx7sephiroth7xx's Avatar
G
Price shipped to 94720 for HKS Hipermax III, please.
Thanks.
Old Mar 3, 2009 | 08:19 PM
gruppe-s's Avatar
Former Sponsor
pm sent
Old Mar 5, 2009 | 08:48 PM
gruppe-s's Avatar
Former Sponsor
Bump Guys
Chickipedia Random Chick Of The Day
Katerina Stikoudi
Old Mar 6, 2009 | 09:09 PM
gruppe-s's Avatar
Former Sponsor
Bump Guys
Tara Conner
Old Mar 8, 2009 | 01:03 AM
Luv2xcelR8's Avatar
Price for HKS and Ohlins shipped to 30022 please
Old Mar 9, 2009 | 02:24 PM
gruppe-s's Avatar
Former Sponsor
pm sent
Old Mar 9, 2009 | 07:31 PM
EEjiggapin0's Avatar
pm price picked up cash for HKS Hipermax III
Old Mar 9, 2009 | 07:45 PM
gruppe-s's Avatar
Former Sponsor
pm sent
Old Mar 9, 2009 | 09:03 PM
gruppe-s's Avatar
Former Sponsor
Bump Guys
Carli Banks
Old Mar 9, 2009 | 11:07 PM
JDM7672's Avatar
HKS Hipermax III shipped to 40245???
