Megan Racing Coilover Suspensions - HUGE DISCOUNT COUPON!!
Old Nov 14, 2009 | 04:50 PM
importdps's Avatar
Import DPS is now stocking all Megan Racing Street Series Coilovers. As one of the largest Megan Racing Distributors, we decided it was time to offer you a deal on this suspension you couldn't resist. These Systems are 32WAY Adjustable and come with top hats. You just can't find a better coilover system at this price period.
Use the following coupon code to see the crazy discount we are offering!!
MEGANST09
*** Megan Racing Street Coilovers - Part #MR-CDK-N3Z - G35 & 350Z - Just USE COUPON ***
Click Here to Order -> http://importdpsonline.com/megan_rac.../i-128594.aspx
When you add it to your shopping cart, enter the discount coupon to see the hundreds you will save.
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in **** at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Features:
- Spring Rates: 10kg Front and 8kg Rear
- 32 Levels of Adjustable Damper
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coilover damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
Online we accept Visa, Mastercard, American Express and Discover Cards. Cash Pickups are also welcome, but please add 8% PA Sales Tax. Installations are just $200 with purchase! We are offering FREE UPS or FEDEX Ground Shipping to all lower 48 states. Hawaii Shipping add $25!!
Thanks
Rick
Import DPS
www.importdpsonline.com
Old Nov 15, 2009 | 12:33 AM
HenryLee's Avatar
PM price to 92373.
Old Nov 16, 2009 | 01:56 PM
g35couture's Avatar
the code didnt work.
Old Nov 16, 2009 | 03:11 PM
importdps's Avatar
Coupon code works perfectly fine. I just checked it and there were 4 orders from yesterday all at the sale price.
Old Nov 18, 2009 | 03:59 PM
importdps's Avatar
Best Prices on the Net!!
Old Nov 19, 2009 | 01:03 PM
importdps's Avatar
Get your Megan Coilover Suspensions
Old Nov 20, 2009 | 03:20 PM
importdps's Avatar
bump!!!!
Old Nov 20, 2009 | 05:08 PM
OCG35's Avatar
code didn't change the price that was listed without code.
How much discount should the code be giving?
Old Nov 23, 2009 | 12:46 PM
importdps's Avatar
I just tried it and the code worked fine. What part number are you using? The sale is only for street series coilovers, not the track versions.
Old Nov 23, 2009 | 02:30 PM
OCG35's Avatar
I just figured out the problem - previously I copy pasted the code, it wont accept that way.
When I typed in the code it showed discount... nice price
Old Nov 23, 2009 | 03:41 PM
HenryLee's Avatar
^+1 It is a big discount. But you do have to type in the code.
Old Nov 28, 2009 | 01:25 PM
importdps's Avatar
All orders processed and shipped!
Old Nov 30, 2009 | 01:54 PM
importdps's Avatar
Back up top!
Old Dec 1, 2009 | 12:25 PM
importdps's Avatar
Old Dec 3, 2009 | 02:48 PM
importdps's Avatar
Bump!!! Megan Racing in stock and ready to ship!! Thank you for all the orders over hte last week!! Plenty of kits still going right out plus you get the FREE SHIPPING FOR THE HOLIDAYS!!
