Megan Racing Coilovers
Old Aug 21, 2010 | 05:06 PM
Marinelli Motorsports's Avatar
We Will Beat or Match Any Megan Racing Price on the Forum!!!
Please PM for details!!!
Now Offering the Swift Track Series!!!
SPECIFICATIONS & FEATURES:
APPLICATION:
Nissan 350Z 2003-08
Infiniti G35 2003-07
SPRING RATES:
F: 65mm ID; 203mm length; 12 kg/mm
R: 65mm ID; 203mm length; 12 kg/mm
DAMPER SPECS:
F: 135mm stroke; 270mm length; A4 X valving code
R: 115mm stroke; 220mm length; A1+ X valving code
- 32 Levels of Damper Force Adjustment
- Rubber Dust Boots
- Wide-Range Adjustable Ride Height
- Competition Spring Rates
- Motor-sport Inspired Mono-Tube Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coil-over damper kits come with 1 year manufacturer-defect warranty.
- All Hardware is Included
Street Series:
Features:
- Spring Rates: 10kg Front and 8kg Rear
- 32 Levels of Adjustable Damper
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
- All coilover damper kits come with 1 year manufacture-defect warranty.
Street-LP (For AWD 03-08, FX 03-08, M35/45 05+, and G37 Coupe 08+)
Features:
- Spring Rates: 12kg/mm Front and 10kg/mm Rear
- Front and Rear Pillow Ball Upper Mounts
- Rubber Dust Boots
- Adjustable Ride Height via shock length adjust-ability
- Aluminum Brackets
Track Series:
Features:
- Spring Rates: 14kg/mm Front and 12kg/mm Rear
- Pillow Ball Upper Mounts
- Rubber Dust Boots
- Aluminum Brackets
Spec-RS Series:
Features:
(F: 62-200-012)
(R: 62-80-180-010)
- Pillow Ball Upper Mounts w/ Front Camber Plates
- External Reservoir for additional oil capacity and separate compression adjustment (New feature)
- Rubber Dust Boots
- Dual-Cylinder Design
- Steel front brackets/ Steel rear brackets
- 32 Levels of Damper Force Adjustable; Separate Compression and Rebound adjustments.
NOTE: Spec-RS will not be able to adjust to stock ride height due to the coil-over design. This coil-over system is design to lower your vehicle to extreme measures
Please PM with Zip Code for best pricing!!!
Old Aug 23, 2010 | 07:11 PM
All PMs replied!!!
Old Aug 24, 2010 | 06:02 PM
All PMs replied!!!
Old Aug 25, 2010 | 05:48 PM
To the Top!!!
Old Aug 26, 2010 | 10:06 PM
All PMs replied!!!
Old Aug 28, 2010 | 12:11 PM
All PMs replied!!!
Old Aug 29, 2010 | 11:26 AM
Bump!!!
Old Aug 29, 2010 | 09:17 PM
boss81's Avatar
Will these work on a 2011 G37 sedan?
Old Aug 30, 2010 | 06:47 PM
All PMs replied!!!
Old Aug 31, 2010 | 09:34 AM
All PMs replied!!!
Old Aug 31, 2010 | 07:19 PM
To the Top!!!
Old Sep 2, 2010 | 06:17 PM
Bump!!!
Old Sep 4, 2010 | 08:14 AM
All PMs replied!!!
Old Sep 6, 2010 | 09:09 AM
Labor Day bump!!!
Old Sep 7, 2010 | 07:09 PM
All PMs replied!!!
