▲▲▲Whiteline Swaybars, Endlinks, Bushings▲▲▲
Old Apr 3, 2011 | 01:07 PM
Marinelli Motorsports's Avatar
Front Sway Bar: 32mm heavy duty blade adjustable.
Key Feature and Benefit
This Whiteline 32mm 2 point adjustable swaybar = more grip = better handling = outright performance - it's the best dollar for dollar handling improvement you can make to your vehicle. This Whiteline adjustable sway bar allows its rate to be altered by increasing or reducing the length of the lever arms. This permits the roll stiffness to be tuned for different situations without replacing the entire bar. The stiffer the bar, the more force required to move the left and right wheels relative to each other. This increases the amount of force required to make the body roll
Rear Sway Bar:20mm heavy duty blade adjustable.
This Whiteline 20mm 3 point adjustable swaybar = more grip = better handling = outright performance - it's the best dollar for dollar handling improvement you can make to your vehicle. This Whiteline adjustable sway bar allows its rate to be altered by increasing or reducing the length of the lever arms. This permits the roll stiffness to be tuned for different situations without replacing the entire bar. The stiffer the bar, the more force required to move the left and right wheels relative to each other. This increases the amount of force required to make the body roll
Endlinks:
Performance sway bar links utilising a heavy duty steel ball joint ends that adjust & rotate to any angular combination. Eliminate sway bar preload via the light weight aluminium bodies provide 25mm centre to centre length adjustment.
Bushing Kits Offered:
-Traction Control Rear Cradle Bushing Kit
-Rear Lower Outer Control Arm (locates in hub / Rear Hub Shock Absorber (lower shock bush) Bushing Kit
-Rear Lower Front Trailing Arm (Lateral Arm) Bushing Kit
-Rear Lower Rear Trailing Arm (Lateral Arm - locates in hub) Bushing Kit
-Rear Upper Front Trailing Arm Bushing Kit
-Rear Upper Rear Trailing Arm (Locates in Hub) Bushing Kit
-Front Lower Inner Control Arm Bushing Kit
-Front Shock Absorber - Control Arm (Lower Shock Bush) Bushing Kit
-Rear Lower Inner Control Arm Bushing Kit
-Rear Upper Inner Control Arm Bushing Kit
Please PM with location for pricing!
Old Apr 4, 2011 | 07:57 PM
All PMs replied!!!
Old Apr 5, 2011 | 03:54 PM
Bump!!!
Old Apr 5, 2011 | 11:26 PM
silose's Avatar
whiteline endlinks 05 g35 coupe front and rear shipped to 90745
Old Apr 6, 2011 | 03:05 AM
G35SedanGrn's Avatar
F & R sway bars for 03 G35 sedan shipped to 94958
Old Apr 6, 2011 | 03:33 PM
All PMs replied!!
Old Apr 7, 2011 | 08:31 PM
Bump!!!
Old Apr 8, 2011 | 11:56 PM
Fiddi1's Avatar
Pls PM pricing on endlinks for 2005 G35sedan shipped to Canada V6Y 1N2.
Old Apr 10, 2011 | 05:23 PM
All PMs replied!!!
Old Apr 10, 2011 | 05:29 PM
prinny's Avatar
Whiteline endlinks front and rear shipped to 92646
Old Apr 11, 2011 | 03:12 PM
Bump!!!
Old Apr 12, 2011 | 02:56 PM
Bump!!!
Old Apr 13, 2011 | 03:01 PM
Bump!!!
Old Apr 14, 2011 | 05:40 PM
SkyWay's Avatar
front lower control arm inner bushings shipped to 68048. I would like to buy these as soon as possible. I would like the fastest shipping as long as the total is under $75. Let me know please.
Old Apr 14, 2011 | 06:52 PM
All PMs replied!!!
