TOKICO DSPECS + TEIN STECH or HTECH Combo! FREE extensions!!!
Old May 17, 2011 | 04:09 PM
THMotorsports's Avatar
Smile TOKICO DSPECS + TEIN STECH or HTECH Combo! FREE extensions!!!
Tokico Shock Kit - D-Spec Series DSP Kit
Product Description
Tokico’s D-Spec Series adjustable shock is a multi-use product that’s the result of sophisticated piston and valving design. In addition, it utilizes a unique variable-aperture bypass, which is controlled by an adjustable slide valve.
D-Spec (damping specific) adjustments change both rebound and compression damping simultaneously. Between maximum soft and hard settings, the D-Spec is infinitely adjustable.
Tokico D-Spec shocks and struts kits are sold in matched sets of four. Each set includes a manual explaining the adjustment process as well as covering suspension tuning tips.
TEIN Springs - STech Springs
Product Description
TEIN S.TECH Spring is an excellent step towards suspension tuning.
They offer approximately a 1.5 inch drop for a more aggressive appearance. Comes with a 1 year limited warranty.
Spring length is guaranteed not to sag more than 5mm and to be clear of any manufacture defects.
Features
One year limited warranty
High-grade material adapted to improve guaranteed satisfaction
Rubber spring protector sheet to prevent noise (most applications)
Specs
Ride Height (F) -1.2in (-30mm)
Ride Height (R) -0.9in (-23mm)
Spring Rate (F) 358lbs/in (6.4kgf/mm)
Spring Rate (R) 274lbs/in (4.9kgf/mm)
TEIN Springs - HTech Springs
Product Description
High Tech is made from a new material called “Vanadium” which is much lighter then other spring and increases flexibility.
Features
All spring are designed specifically to fit each car for maximum performance
About a 1 inch drop for a more attractive appearance
Comfortable ride quality is still maintained by using the OEM bump rubber and noise protection sheet (available for most model)
Specs
Ride Height (F) -0.6in (-15mm)
Ride Height (R) -0.3in (-7.5mm)
Spring Rate (F) 324lbs/in (5.8kgf/mm)
Spring Rate (R) 263lbs/in (4.7kgf/mm)
FREE WITH COMBO!!!
DSpec Adjustment Extensions
***If you prefer different springs or different combinations let me know and I will make it happen!!!***
SUPER COMBO DEALS!!!
PM US OR CALL US FOR BEST PRICES AVAILABLE AND FOR ANY DESIRED COMBO DEALS!!!
Looking forward in hearing from you.
Thank you,
Adam
THMotorsports
800-959-0145
www.thmotorsports.com
adamk@thmotorsports.com
AIM = adamkthm
Old May 20, 2011 | 01:30 PM
All PMs sent...sweet combo deals!!! LMK guys
Old May 21, 2011 | 05:21 PM
Manual G's Avatar
D-specs and adjustment extensions shipped to 07026. No springs
Thanks
Old May 23, 2011 | 07:27 PM
Thanks
PMd ya!!!
Old May 24, 2011 | 08:32 AM
07GRider's Avatar
I have a 2007 sport and want a drop... what is the difference between Stech spring and Htech springs?? i want the best for my car ....
Ps i dont want to be a noob but here it go Do i have to change the rest of my suspension meaning (shocks) when i change my springs???? the reason i ask is because i have the sport suspension and i dont want to destroy my suspension with this modification
Old May 24, 2011 | 12:14 PM
GXXXV X's Avatar
it is recommended that you change your shocks when you drop or else the life of your stock shocks will decrease rapidly
Old May 24, 2011 | 12:30 PM
psycobusa's Avatar
D-specs and adjustment extensions shipped to 77386. No springs
Old May 24, 2011 | 05:19 PM
GXXXV X's Avatar
d specs and adjustment extensions shipped to 15241?
Also please let me know a separate price for d specs, extensions, and s tech springs shipped to same place? Thanks
Old May 24, 2011 | 07:01 PM
PMd ya
thank you
it be wise to do so...in time the stockers will die...sooner than later. just like wsolo08 mentioned.
PMd ya
Old May 24, 2011 | 08:17 PM
KingCobra's Avatar
Price shipped for DSpec with Htech
Price shipped for Dspec with Stech
to 91311
I have an 06 Coupe
Old May 25, 2011 | 01:28 PM
PMd ya!!
Old May 26, 2011 | 02:22 PM
Checkout our Facebook for updates on our race car!
THMRacing STi Facebook
Old May 26, 2011 | 02:29 PM
G35SedanGrn's Avatar
Dspecs no springs shipped to 94598
Old May 27, 2011 | 04:03 PM
$PM sent!
Old May 31, 2011 | 03:11 PM
