Phantom Air Cup Kit Suspension Now Offered at Statik Performance!!
Old Jan 27, 2013 | 08:36 PM
  #31
mrwong@statik's Avatar
Dual Compressor Option - The Full or Front Kit only comes with 1 Compressor. However I opted to get 2 since I like the look better.
Air Line coming out and Zip Tied to the brake hard line. All Air Lines are Run inside of the car. it's 1/4 inch air line so it's pretty easy to hide and run inside.
Switch Placement. Most ideal place and easy access also didn't have to cut new holes into anything.
Switches relocated into the center console. Just to keep em functional.
Old Jan 27, 2013 | 09:09 PM
  #32
Cux350z's Avatar
looks like some good height out of them for sure.
What Kg springs?
Any pics of the rear setup. Stock spring bucket?
Old Jan 27, 2013 | 09:21 PM
  #33
10kg front and 8kg rear
Stock Spring bucket. Sorry none yet. Will take some this week.
Is the travel on the Exotics about the same?
Old Jan 27, 2013 | 09:24 PM
  #34
Frankieg35's Avatar
Damn!! These give u a lot of height..
Old Jan 27, 2013 | 09:49 PM
  #35
Yang88she's Avatar
Is this price valid for g37 owners?
Old Jan 27, 2013 | 09:52 PM
  #36
rhampsterwha2's Avatar
Thanks, I like what you did with the switches only ill probably reverse what you did and ride partially aired to get lips away from fenders so I don't have to constantly go up and down (terrible roads )
Do you think it would be possible to mount the air tank and compressor in the spare tire hole? I took mine out bc bbk wont let it fit anyway and putting it all there will be real clean and not loose any trunk space
Old Jan 27, 2013 | 10:00 PM
  #37
Frankieg35's Avatar
U could get a round pancake tank that mounts where the spare tire goes.. Thats what id do..
Old Jan 27, 2013 | 10:14 PM
  #39
Zioxx's Avatar
Dang getting my hyped about picking these up instead of the seats lol
Old Jan 27, 2013 | 11:10 PM
  #40
Frankieg35's Avatar
How do u run this with no tank??
Old Jan 27, 2013 | 11:26 PM
  #41
Jaygotboost's Avatar
So basically coil height has to be set for driving then the cup raises the car AmateuRN? Opposed to bags letting you slam on frame then up again?
Old Jan 28, 2013 | 12:05 AM
  #42
Yes they do sir and you retain the coilover feeling
Yes sir it is. If you guys want to get in on the group buy i'll open it up to you guys as well.
Yup its possible you can get a round tank just like frankie said.
U could get a round tank that mounts where the spare tire goes.. Thats what id do..
Yes sir
Should roll by and check it out!
It would be run with a fitting 3/8 to 1/4 and the compressor would just be wired to a switch i'm assuming. However it's not recommended because of the load it would put on the compressor. However if your roads are nice and don't plan to air up a lot this setup will work.
Yes Sir, Pretty much however the feeling of the car on both cups and bags is completely different.
Old Jan 28, 2013 | 12:11 AM
  #43
What I want is to keep my aggressive drop but raise it when I need to, I'm definitely in this GB... FTW
Old Jan 28, 2013 | 10:25 AM
  #44
Infinite1's Avatar
20 Year Member
Platinum used to have a flat air tank..Do they still offer that option? I'm looking at it from a space saving perspective.
Old Jan 28, 2013 | 04:19 PM
  #45
Sorry they don't offer that option anymore.
