Voodoo13 Suspension Arms SAME DAY SHIPPING!
Old Feb 2, 2016 | 03:43 PM
StreetStandard's Avatar
Talking Voodoo13 Suspension Arms SAME DAY SHIPPING!
Offering the best in suspension arm solutions for your 350Z/ G35 from none other than the good guys at Voodoo 13!!
Front Upper Control Arms $760 MSRP, PM for forum pricing!!
Voodoo13 dual adjustable front upper control arms for the Nissan 350Z and Infiniti G35 are made from CNC milled aerospace grade 6061 aluminum, sporting not only dual adjustment functionality, but also an innovative impressive design. The slim upper spindle mount helps prevent upper control arm slap from excessively lowered cars, while utilizing an encased spherical bearing design that prevents deformation from impact or high driving forces over time. The easy to reach dual adjusters allow for both caster and camber correction, all while never being unbolted from the car, to suite any application.
Adjustment Range: -4.5 to +1 degree relative to stock arm and depending on ride height. 4 degrees of caster adjustment is available separate from camber.
Features:
*Offset spacers allow extra caster adjustment
*CNC Machined Aerospace Grade Aluminum
*Slim profile for extremely lowered vehicles
*Unique Design for aesthetics and 100% functionality
*Made in the USA QA1 spherical bearings and rod ends
Rear Toe Arms $200 MSRP, PM for forum pricing!!
Voodoo13’s 350Z/ G35 Rear Toe Arms are designed, engineered and tested on race tracks across the globe using feedback of top tier drivers and technical directors. Precision CNC machined adjusting rod from high strength 6061-T6 aluminum coated in MIL-A-8625 Type III Hard Anodize, CNC laser cut and bent steel brackets with TIG welded construction and stainless steel CNC’d spacers are used to ensure they will withstand abuse from street cars and track cars alike.
We use QA1 XM Chromoly Steel heim joints that are heat treated for strength and durability. The spherical rod end is self-sealing and self-lubricated because of their Nylon/PTFE injection molded race that keeps out dirt and debris.
NOTE: These toe arms are only for those who have switched to true rear coilover suspension. Our arms replace the OE spring bucket and provide a wide range of toe adjustment, a must for lowered cars.
Rear Camber Arms $190 MSRP, PM for forum pricing!!
Voodoo13 350z – G35 rear camber arms provide a wide range of adjustment for those with lowered vehicles that want to correct their rear camber and improve handling.
Our camber arms are constructed from a 6061-T6 aluminum hex for easy adjustment and are CNC turned for precision fitment. Brackets are fabricated from machined fit parts and TIG welded together guaranteeing strength and quality.
For the ultimate in performance rod ends we use USA made QA1 XM Endura series chromoly steel heim joints which feature a self-lubricating and self-sealing Nylon/PTFE injection molded race that keeps dirt and debris out.
Adjustment range: 8 degrees of total adjustment. -3 to +5 from stock arm.
You may be interested in these items as well!
Front Akebono Bracket Adapter $190 MSRP, PM for forum pricing!!
The Voodoo 13 caliper adapter brackets for the 2003-2008 Nissan 350z and 03-07 Infiniti G35 Coupe allow you to bolt on the much larger 14″ Front Akebono brakes from the 370z and G37 Sport models. These brackets are CNC machined from high quality 6061-T6 aluminum which is extremely resistant to corrosion and the elements. Grade 10.9 zinc plated hardware is included.
Give us a call today (480)-245-6567 or feel free to send us a PM or email to brandon@streetstandard.com and include your shipping postal code, to inquire about pricing, as well as any other questions you may have!
Old Feb 3, 2016 | 03:24 PM
Old Feb 4, 2016 | 02:05 PM
Bump! Call or PM us today for your quote!!
Old Feb 5, 2016 | 07:06 PM
TO THE TOP!
Old Feb 8, 2016 | 02:49 PM
Bump! These arms are made right here in the glorious U.S of A!!
Old Feb 9, 2016 | 01:53 PM
Bump! These arms are in stock and ready to ship!
Old Feb 10, 2016 | 06:41 PM
Bump! To the top!
Old Feb 12, 2016 | 02:39 PM
Bump! PMs answered!
Old Feb 15, 2016 | 02:43 PM
PM's answered, Bump!
Old Feb 16, 2016 | 11:39 AM
Still have arms in stock and ready to ship! Bump!
Old Feb 17, 2016 | 12:38 PM
Old Feb 18, 2016 | 05:17 PM
We do competitive price matching! PM us for more information!
Old Feb 19, 2016 | 12:04 PM
PM's answered!
Old Feb 22, 2016 | 01:26 PM
Bump! All inquiries replied to!
Old Feb 23, 2016 | 12:14 PM
Bump!!!
