Upgrade Vortech Coupe-Progress Thread
Old May 21, 2007 | 02:31 PM
  #46
FastDontLie's Avatar
...we dont need roads...
Cause thats how I felt yesterday!!!! And drew you need to tap your pan, im getting the NPT tap today.
Old May 21, 2007 | 02:43 PM
  #47
G Thizzle's Avatar
oh yeah huh... i forgot you were on that half baked thing.... i need to go to home depot and get that step drill.... i am going to tap the pan tonight for sure!!!
Old May 21, 2007 | 03:09 PM
  #48
Here are a few from my phone.
Old May 21, 2007 | 04:20 PM
  #49
Serg's Avatar
what is that thing ?
Old May 21, 2007 | 04:25 PM
  #50
G Thizzle's Avatar
Serg are you going to get out there tonight??? i will be there around 5ish... if you can come by my house around 430....
Old May 21, 2007 | 04:33 PM
  #51
Serg's Avatar
I have a function to go to (tool concert) it's been cancelled twice already. I am off all day tomorrow so I am down for tomorrow if you are still working on it! What was the outcome on the bumber fitment?!
Old May 21, 2007 | 04:36 PM
  #52
G Thizzle's Avatar
The out come was a total success...
Old May 21, 2007 | 05:03 PM
  #53
dan61177's Avatar
That is the Fuel Pump assembly
Old May 21, 2007 | 05:06 PM
  #54
venommaxr33's Avatar
Must Go Faster!!
its got to be comforting for rear seat passengers to know they are sitting on 20 gal of fuel. although the driver aint to far away...might as well be a motorcycle
Old May 22, 2007 | 06:17 PM
  #55
Update:
Fuel return-just need to add return line, and see if there are any leaks.
Injectors- Need to soder 3 more injectors and they are done.
Utec-Ecu is uninstalled and waiting for me to go to SGP. flash the Utec, comeback and install on the car and get it ready to drive up to SGP to tune.
Pulley-This will be the last thing I do. Since me and Drew have to switch at whatever time. (No big deal, Easy work)
Hopefull it will up and running Saturday.
Old May 22, 2007 | 06:30 PM
  #56
dan61177's Avatar
Utec should have a base map already in it capable of getting you to SGP safely.
Old May 22, 2007 | 06:42 PM
  #57
Must Go Faster!!
it has the base map but not for the 440cc injectors. he's gonna let them flash the utec and then install on the car so he can drive the whole thing up there for a proper tune
Old May 22, 2007 | 07:10 PM
  #58
dan61177's Avatar
The Utec with the base map will push the 440s. they will just be at a very light duty cycle. IT would be fine imo
Old May 22, 2007 | 07:15 PM
  #59
G Thizzle's Avatar
here is my update....
Piping is ran except the Outlet pipe from the SC....
Need to run the oil feed line
Plug in UTEC
install the Walbro 255
swap mounting brackets with Daniel...
Run the gauges... Boost...Fuel Pressure... AEM Wideband (Elite is going to weld the bung plug)
Not a whole lot left to do.... just little things imo.... should be done by this weekend also and be ready to drive Wednesday morning to SGP for Tune and Dyno!
Old May 23, 2007 | 11:25 AM
  #60
would rather be safe than sorry.
