My morning at Eibach .
Old Feb 6, 2007 | 05:10 PM
terrycs's Avatar
I had another thread going to see if there was any interest for a group rate on spring install with 4 wheel alignment in Southern Cal. There did not seem to be much interest, so I decided to strike out on my own.
I had my car at Eibach in Corona, CA for them to install their new 2007 G35 Pro-Kit springs onto my car this morning. The install and alignment was pretty quick … I was outta there by lunch time. I have attached before and after pictures. Sorry, the car is pretty dirty . I knew there was rain coming in the next few days so I didn’t bother to wash it.
The car was evenly lowered all the way around. The actual numbers are 31mm lower in front and 33mm lower in back (with a full tank of gas). Some things I learned while I was there:
There is about 10mm more fender clearance on the front than on the back by design from the factory. You may see that when you look at the pictures. The R&D project manager told me that he is considering lowering the front a little more which will even out the fender clearance for the production springs which should be available in about a month.
There are slight variations in dimensions on the front springs between the 2006 and 2007 model year.
Note that the rear alignment still has a slight negative camber because there was no more adjustment available. I am personally going to get a camber kit to fix that very soon. The front alignment adjusted back into spec.
Overall ride quality was unaffected. In addition, I actually found it was easier to get in and out of the car.
For those interested, the production part number is already on their website (although not available yet).
Also … they are definitely in need of a G35x for measurements. They have not determined if there is sufficient interest to lower the X version yet, so if there is, speak up. I gave the R&D manager the address to this link so he will no doubt be checking this out.
BEFORE:
During:
AFTER:
Old Feb 6, 2007 | 05:18 PM
mfecko's Avatar
Looks sick ... How much did this run you (parts + install)?
Old Feb 6, 2007 | 05:21 PM
RED_G35S's Avatar
yah the front needs to be lower a little bit...
it looks good..
wonder if i should do it... i've had coilover on my civic before and it's kinda rough... hope the springs will be fine.. but there are quite a lot of bumps here in NorCal.. stock shocks are fine with the aftermarket springs???
Old Feb 6, 2007 | 05:27 PM
bertmauricio's Avatar
Very cool!!!
Old Feb 6, 2007 | 05:33 PM
FrIsCo G35's Avatar
those of you with the springs installed, are you guys experiencing any squeaks or clunking noises? only reason why i ask is because when i had my rsx i had squeaks and clunking noises on turns.
terrycs's Avatar
No charge
Old Feb 6, 2007 | 05:34 PM
terrycs's Avatar
Squeaks can be minimized by not putting the coil end all the way into the bushing pocket. Leave about 1/4" clearance.
Old Feb 6, 2007 | 05:35 PM
acidrane's Avatar
call me crazy but id rather raise the rear a bit to match the front, not the other way around. i ahd a pretty low car for 3 yrs and not having to worry about scraping or busting up the front bumper cuz of the parking block is a real plus to me atm. id want top lower it but not that low. just enough to hav less wheel gap.
vick
Old Feb 6, 2007 | 05:36 PM
terrycs's Avatar
it looks good..
I've never used coil overs on any of my past cars. I didn't think I needed the adjustability.
Old Feb 6, 2007 | 05:38 PM
GEE35FX's Avatar
That looks excellent Terry
Old Feb 6, 2007 | 05:39 PM
terrycs's Avatar
vick
I thought about that as well. I have "standard" parking blocks in my garage. I'll check out the clearance.
Old Feb 6, 2007 | 05:48 PM
terrycs's Avatar
Originally Posted by bertmauricio
Very cool!!!
Thanks, I just happended to be at the right place at the right time.
Old Feb 6, 2007 | 05:52 PM
da mayor's Avatar
nice before and after.... are they working on something for the awd sedan? someone has to have an awd near by.
i wish i were in cali --
Old Feb 6, 2007 | 06:03 PM
G-Whizzer's Avatar
WOW. They should come standard like that....
Old Feb 6, 2007 | 06:09 PM
terrycs's Avatar
They need a G35X for measurements if anyone in So Cal is interested.
